Crankshaft pulley won't come off.(Bolt is out)
Old Mar 9, 2006 | 12:59 PM
98civic94gsr's Avatar
Default Crankshaft pulley won't come off.(Bolt is out)
got a 94 gsr with a lightweight crankshaft pulley. I've got the bolt out so the crankshaft pulley should just come out but it doesn't.
It is stuck on thier pretty good. Any tips on how to get it off?
I have tried sticking a screwdrive between the back of the pulley and motor and prying it off to no avail.
Also when I pull on my pulley to remove it it slides maybe and eighth inch, not the pulley either everthing its connected to. Is that normal to have a little side to side play>?
Help me get it off!
Thanks again,
98civic94gsr
Old Mar 9, 2006 | 01:07 PM
Default Re: Crankshaft pulley won't come off.(Bolt is out) (98civic94gsr)
Anybody?
Old Mar 9, 2006 | 01:18 PM
Somebody has to of had this problem before.
Old Mar 9, 2006 | 01:23 PM
nitrofish420's Avatar
Try rapping on it with a hammer and pry again. It's apparently stuck somehow, so maybe some banging will loosen it. It sounds crude, but it should work. Just don't wail on it with a 10lb. sledge or anything...
Old Mar 9, 2006 | 01:25 PM
Default Re: Crankshaft pulley won't come off.(Bolt is out) (nitrofish420)
I've hit around it with a hammer and it will not pop free. I guess I will go ahead and hit it a little harder.
Any other ideas?
Did I bend something?
Thanks,
98civic94gsr
Old Mar 9, 2006 | 02:10 PM
Dutch-VTEC's Avatar
Just take a hammer and hit on around the diameter of the pulley. After a couple good wacks at it, if it is still on, maybe drench it in some wd-40. Let it soak for a minute and try it again. If that doesn't work. You can buy a pulley remover at a local hardware store. You might even be able to rent one from a checkers or autozone.
Old Mar 9, 2006 | 02:42 PM
ED7's Avatar
ED7
Default Re: Crankshaft pulley won't come off.(Bolt is out) (Dutch-VTEC)
Use two hands and try to shake while pulling off. Just work it off.
Old Mar 9, 2006 | 03:22 PM
Yambor's Avatar
Default Re: Crankshaft pulley won't come off.(Bolt is out) (ED7)
does the damn pully have holes in it so u can use a puller?
Old Mar 9, 2006 | 03:36 PM
skunked's Avatar
Default Re: Crankshaft pulley won't come off.(Bolt is out) (JH4DC4-2GSR)
soak with some liquid wrench.
Old Mar 9, 2006 | 03:45 PM
mattcivic's Avatar
Default Re: Crankshaft pulley won't come off.(Bolt is out) (skunked)
get a friend or family member to take a hammer and gently tap it while u pull on it hard just keep tapping it gently this is what i do for stuborn axles and crank pullys always seems to work.
Old Mar 9, 2006 | 03:49 PM
PoorStreet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dutch-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Just take a hammer and hit on around the diameter of the pulley. After a couple good wacks at it, if it is still on, maybe drench it in some wd-40. Let it soak for a minute and try it again. If that doesn't work. You can buy a pulley remover at a local hardware store. You might even be able to rent one from a checkers or autozone.</TD></TR></TABLE>
Old Mar 10, 2006 | 09:26 AM
Default Re: Crankshaft pulley won't come off.(Bolt is out) (PoorStreet)
Ahhh I ended up prying it off with a hammer after hitting it with a 3lb sledge and soaking it in wd.
Its off now.
Thanks guys,
98civic94gsr
mem94043
Feb 21, 2012 08:56 PM
remoer
Apr 15, 2007 01:48 PM
SiRay13
Apr 5, 2007 06:09 PM
I CRX I
25
Dec 11, 2006 05:38 PM
SuicideSlide
Oct 9, 2004 08:27 AM
