Idle Air Control Valve and low idle
I have a really low idle so I might need to be changing my Idle Air Control Valve on my D15B Vtec
what can i use one from?
i have one from a B16 motor sitting in my garage, will that work?
It should work, they are pretty much the same... But type-r b series is way different... If the bitch bolts up then there is your answer.
Anyhow, why do you think thats you idle problem. It holds a smooth low idle. Than thats not it. Did you try the air adjustment screw on the TB. Or maybe even the idle adjustment screw on the TB under the cable. Maybe your timing id off. So many things that could equal a low idle problem. Maybe even a vavle adjustment.... But start with the basics.
TearSDMF89dx
Jan 3, 2012 04:31 AM
sporkcrx
Nov 9, 2002 06:59 PM
