Please help car wont start!!
My 91 hatch si doesn't start
. It was working perfectly until yesterday I tried to start it up and the engine did not turn at all. I checked the battery (cleaned the terminals) and replaced the main relay and still nothing
. Lights and radio turn on. What else should I check???
Please help.
THank you
Modified by baggelis at 2:44 PM 3/9/2006
Modified by baggelis at 2:45 PM 3/9/2006
. Lights and radio turn on. What else should I check???Please help.
THank you
Yes fuel pump comes on, I doubt that would be the problem since the engine does not crank, if it was the fuel pump then it would turn over.
Thanks for the suggestion.
Resolved!!
The clutch pedal has a small button on the upper end that when pressed it touches a switch that allows current to go to the starter. The button crumbled into little peaces (very old plastic) so I replaced and it works. Same thing happens to the brake pedal button and the brake lights stay on.
have you checked your grounds?
