Distributor - DX to SI
Old Mar 31, 2002 | 03:06 PM
CimorelliCRX's Avatar
Default Distributor - DX to SI
Okay, well as most of you all know my ZC rod bearing spun, so for now I am ognna throw my old dx motor back in. But I am running the SI wiring and stuff. So what I was wondering is will my DX dizzy work anyway at all? I read about someone here wiring theres up...
If not, can I gut my ZC distributor and put the internals in my DX and have it work? If that will work thats what I am gonna do.
Thanks for the help in advance.
Old Mar 31, 2002 | 06:03 PM
Default Re: Distributor - DX to SI (CimorelliCRX)
ttt
Old Apr 2, 2002 | 04:27 PM
last time, i need to know this!!!
Old Apr 3, 2002 | 12:18 AM
CRX-RX's Avatar
Find yourself an Si or HF distributor. You can't swap the internals for the same reason that you can't use a DX, neither model has an internal crank angle sensor. No one has ever used a DX dist with an MPFI ECU, that sensor is not in there, so it will not function properly.
92coupe
12
Nov 5, 2010 08:30 PM
crxben
Oct 25, 2006 02:44 PM
turbohf
13
Feb 20, 2003 04:38 PM
Agent Daimon
Dec 17, 2002 03:42 AM
the DR.
Jul 1, 2002 06:14 AM
