1990 Honda Accord EX idle problem
Fuel Injected. When the engine is cold and I start the car, it idles around 1200 rpm. When the engine warms up the idle drops to around 600 rpm. Then when you push the accelerator the engine stalls. When you restart the car and give it gas, it cuts off after you let off the accelerator. I just put a new distributor on the car including the cap. I also replaced the engine computer with a used one.
