tranny
Old Mar 9, 2006 | 04:12 AM
ekb16's Avatar
Default tranny
ive got a b18c with a s80 lsd in my ek...everything was working fine until a few days ago...when i put it in reverse it doesnt go all the way in and my backup lights dont work..when its in reverse it wont come back out until i hit it out...i check the linkage, changed trans oil, and checked the backup light switch already and it works but its still doing the same thing...i even tried going into another gear b4 i put it in reverse but its the same...any input would be great thanks
Old Mar 10, 2006 | 03:23 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: tranny (ekb16)
your 5th or reverse synchro mesh on the sleeve probably has burrs and is binding on the 5/R hub...not allowing it to get all the way onto the gear. or your 5/R shift mechanism tab for the fork is bent.
jordan_rael_420
Oct 18, 2010 04:57 PM
blankslat5
Nov 10, 2008 04:27 PM
systemoverload
Jun 2, 2006 10:50 PM
ExplicitSpeed360
Feb 28, 2006 08:30 PM
Burlyirishdude
Nov 23, 2004 09:34 AM
