Break Fluid leaking from inside my calliper
If it is leaking from the "inside"... and when you mean inside im taking you mean behind the inside brake pad? If so id have to say the piston has a faulty seal.
Yeah. It faulty seal if its coming from INSIDE the caliber. If it comes somewhere around caliber, i would suspect bleeding- nipple got loosen. Or bad brakeline/ hose.
no one has mentioned them, cause i am bettering they assume you know what thye are, but here are your options.. get a caliper rebuild kit, (which IMO takes too much time) or just get a new caliper. i would replace the caliper. its not that much more than the rebuild kit, and you just take the old one off and put the new one on.. lot quicker and less messy
trianglegreg
14
Apr 15, 2007 05:22 PM
hondatuner20
11
Apr 14, 2006 02:03 PM
i think it is the seal
