NEED Pics of B18A in CRX/Civic My vac lines are screwed up! HELP!!
Old Mar 31, 2002 | 01:57 PM
Toxic's Avatar
Default NEED Pics of B18A in CRX/Civic My vac lines are screwed up! HELP!!
Just like the title says. I took the motor out of my donor integra and it was running execellent. Now its in the crx and I hooked everything up and put the vac lines where I "THOUGHT" they went and when I started it for the first time it sputtered then died! Second time it just sputtered but kept running for like 10sec but then again died ! So I need good pics or a detailed diagram.
Thanks
Old Mar 31, 2002 | 02:49 PM
EightOhOne's Avatar
Default Re: NEED Pics of B18A in CRX/Civic My vac lines are screwed up! HELP!! (Toxic)
i can go take pics of my stock engine vacuum lines..but i doubt that would help you any
Old Mar 31, 2002 | 05:58 PM
Toxic's Avatar
Default Re: NEED Pics of B18A in CRX/Civic My vac lines are screwed up! HELP!! (EightOhOne)
Any help at all would be cool.
Old Apr 1, 2002 | 01:20 AM
KKHybridCRX's Avatar
What year B18A? I have a '92 B18A in my '89 CRX.
For my car, I ditched the metal tubing running over the intake. AFAIK, there should be one extra vac line coming out of the back of the teg intake. It is for the fuel pressure regulator cutoff solenoid. The CRX didn't come with one. I just plugged it. I don't have a digital camera, but my friend has one at his shop. If I get a chance to go by, I'll take a few shots and post them.
Old Apr 1, 2002 | 06:12 AM
Doodoo's Avatar
Default Re: NEED Pics of B18A in CRX/Civic My vac lines are screwed up! HELP!! (KKHybridCRX)
Also, what year and trim CRX?
Old Apr 1, 2002 | 08:52 AM
Toxic's Avatar
Default Re: NEED Pics of B18A in CRX/Civic My vac lines are screwed up! HELP!! (Doodoo)
92 B18A into my 88 CRX Si. Car is running like crap! And motor was in perfect working order when I took it out of the teg. I also eliminated most of that metal bracket but used some because IU ran out of vacuum hose. I also grabbed those selinoids off the firewall of the teg, and used them in the crx , but I still have the crx ones. Thanks I would really appreciate the help!
Old Apr 1, 2002 | 02:47 PM
Toxic's Avatar
ttt
Old Apr 2, 2002 | 09:41 AM
Toxic's Avatar
please?
Old Apr 2, 2002 | 10:27 AM
HumanResource's Avatar
Thought is read,
"...My tan lines are screwed up! HELP!!...."
Couldn't help you there man!
[Modified by Chris90STD, 7:28 PM 4/2/2002]
solerizr
Nov 23, 2006 10:14 PM
01h22lude
Oct 7, 2004 02:59 PM
crxforum
Aug 12, 2003 10:28 PM
