ok here are some pics..
ive had many people ask for pictures of my civic to see things like the gsr full leather interior, gsr guage cluster swap into stock civic dash, brembo cross-drilled rotors.. i took these pics before it got dark but i did finish up detailing the like the trims and other small things.. got any questions?? comments?? everything is welcome to a point..
http://www.imagestation.com/album/pi...?id=4291958855
nice and clean. hey where did you get those fifty fifty tail lights? ive been looking for them but no one seems to know where to get them. also can you list the modification you had to do to install the teg cluster? my car kind of looks like yours but without the gsr rims and fifty fifty's. nice *** car!
Car looks pretty good. Just curious, will you be swapping in a B18C to go with that cluster? Do you have a swapped out ECU? I guess I don't understand why you have a cluster with the redline moved up if the d16(which I presume you have) has a redline of around 7K. Not flaming, just not seeing the whole picture.
Was it hard to fit the GSR dash into your car? What kind of modifications did this require??
I just noticed how ****** huge that muffler is... hopefully it does good, butr it looks like a fart can
thanks for the compliment b18c5-eh2 regarding the integra guage cluster.. i really like the way it looks also..
the 50/50 tail lights were bought off ebay.. think i paid $70 for them and they are a lot better than stock and 1000 times better than the altezzas that cost more..
there is a stock d16z6 motor under the hood.. didnt feel like taking pics of a stock motor.. once i get the swap ill take under the hood pics.. as for putting the teg cluster gauge cluster w/ the 8100k redline is because im going to be swapping in a b18c1 motor and ecu in a few months.. i never take the car to redline so im not worried about blowing it out by hitting 8100 cause i have the shift light set at 6500k so that will never happen..
[Modified by 95CivicEX, 10:51 PM 3/31/2002]
i dont know if you have been lazy... but 9000RPM tachometer in the cluser!!! why would you need a monster tachometer??
no it was not hard at all.. it just required some minor cutting w/ a dremal of the stock dash (black thing in front of cluster) to make it fit.. as you can see there is small gap cause i cut to much and just been to lazy to go to a junkyard and buy a new one to try it agian.. all in all it took about 2 hours to do the project including all wiring and etc..
Do you have the wiring diagram to make this project happen? I am interested but would like more info on it first. Would i need the plugs from a Integra cluster?
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
wow, that diagram is nice, but let me get this straight. If I'm going to do this, I gotta find reroute all these wires? Like...
1. blu tach signal
would recieve the wire that WAS plugged into
8. blu tach signal
Just clearing things up. Thanks.
1. blu tach signal
8. blu tach signal
Is the rear seat out of a 4 Door GSR car??
LOOKS GOOD!!!
How hard was it to install the Rear seats??
I want to put some 4 door seats into my 99 SI.
thanks
DK
LOOKS GOOD!!!
thanks
DK
1. blu tach signal
8. blu tach signal
1. blu tach signal
8. blu tach signal
LOOKS GOOD!!!
thanks
DK
LOOKS GOOD!!!
thanks
DK
mine, so I give you a good choice on that one
