GSR ENGINE INTO A 96 EK HATCH I NEED HELP
Old Mar 8, 2006 | 07:56 PM
STRAKTUS's Avatar
Default GSR ENGINE INTO A 96 EK HATCH I NEED HELP
I NEED HELP WITH WIRING DIAGRAM ON A OBD2 P72 ECU? ALSO WHAT TYPE ON MOUNTS OR BRACKETS SHOULD I USE? WHICH MOUNTS CAN I USE FROM THE GSR ENGINE? THANK FOR YOUR HELP
Old Mar 13, 2006 | 09:26 AM
crv-techu's Avatar
Default Re: GSR ENGINE INTO A 96 EK HATCH I NEED HELP (STRAKTUS)
buy a 96 or up ex engine harness and all you will have to wire up is the duel stage in the manifold.or buy a skunk2 intake manifold and a straight runner ecu like p28'p73 or a newer Si ecu depending on what obd your going to use
FTNW
Dec 3, 2011 01:48 AM
STRAKTUS
Mar 8, 2006 08:00 PM
etrnlecho
Sep 10, 2002 10:13 AM
