fan stays on?
Old Mar 8, 2006 | 07:44 PM
thapimpfromchi's Avatar
Default fan stays on?
Sup guys, just got finished swapping out a d16zc with a d16a6. got everythign hooked up, turned the key to the acc position and my radiator fan started blowing. it just stays on. i didnt mess with any wiring other than the wires for the distributor. any ideas what could be wrong?
Old Mar 9, 2006 | 04:18 AM
Default Re: fan stays on? (thapimpfromchi)
bump
Old Mar 9, 2006 | 04:42 AM
Mugencrxsir1's Avatar
check your thermostat, they get stuck open and close after a while, just replace it, your probably over due anyways.
Old Mar 9, 2006 | 05:18 AM
Default Re: fan stays on? (Mugencrxsir1)
i dont think thats the problem, i had it running for about 10 minutes yesterday, and she heated up just fine, blew hot air and everything.
Old Mar 9, 2006 | 05:49 AM
tayhas's Avatar
ck the temp switch under the dist. make sure the wires are ok. if they touch the fan will stay on.
Old Mar 9, 2006 | 06:07 AM
davens's Avatar
Check the fan switch...they are designed to fail "on".
A fan thats always blowing is a nuisance. A fan that never comes on is a blown headgasket.
Old Mar 9, 2006 | 09:01 PM
Default Re: fan stays on? (davens)
got it, had the wires reversed under the IM. thanks for the input though.
EJ8Squad919
Jun 30, 2014 06:46 PM
dudeomega2000
Jan 6, 2008 09:51 PM
FONK
Jan 12, 2006 03:03 PM
altoid
Aug 5, 2003 03:22 PM
Anthonyl469
Mar 18, 2003 01:48 PM
