Help me figure out this noise in my head...
Old Mar 8, 2006 | 04:15 PM
blackhatchb20's Avatar
Default Help me figure out this noise in my head...
Here is a movie of what the noise sounds like. Yes it quicktime, its the only format i could do
http://home.comcast.net/~linda...4.MOV
I just replaced all my LMA's today, the new ones are in in this video, 8 ITR LMA's, we checked my valve clearance, and adjusted what need to be.
THIS IS BAFFLING me i how no clue what it is, its not rod knock because it goes away at high rpm's and it changes pitches, well it sounds like it to me atleast. car still pulls fine. compression tested at 200 across.
PLEASE help me figure this out before i encur any long term damage. Or do i just need a buy a new head?
TIA
Matt
edit: its the fast paced ticking noise i'm wondering about.
Old Mar 8, 2006 | 04:42 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Help me figure out this noise in my head... (blackhatchb20)
What was the engine temperature when you checked the valve clearance? Have you tried the screw driver to the ear trick to isolate the noise origin?
Old Mar 8, 2006 | 04:53 PM
Default Re: Help me figure out this noise in my head... (Dogginator)
engine wasnt HOT, it wasnt cold either. closer to cold than anything. but we put it to .007 intake and .008 exhaust.
One of my intakes was at .15, could that have damaged a rocker arm and this is causing the tapping?
Old Mar 8, 2006 | 04:55 PM
Dogginator's Avatar
Daisy... Daisy...
When you pulled the cams, did any lobes appear to be excessively worn? Could that sound be an injector (hard to tell with sound file)? I think the screw driver is going to lead you to the source.
Old Mar 8, 2006 | 04:59 PM
We unplugged each injector, and the noise stayed the same. the lobes didnt appear to have any wear what so ever on them. a screw driver put it inbetween #2 and #1 intake side.
Old Mar 8, 2006 | 06:14 PM
Dogginator's Avatar
Daisy... Daisy...
Have you checked the rocker arm clearance on those two cylinders? Check to see if they are loose on the rocker shaft.
Old Mar 9, 2006 | 04:41 AM
Dogginator's Avatar
Daisy... Daisy...
BTW: you can run the car briefly with the valve cover removed to better isolate the noise. Please be careful as to what you touch while the engine is running.
Check this thread for what I mean (graphic, do not view if you have a weak stomach):
https://honda-tech.com/zerothread?id=1522921
Old Mar 10, 2006 | 03:58 AM
Dogginator's Avatar
Daisy... Daisy...
Do you think the a VTEC rocker could be worn enough that it has free travel between the camshaft and the LMA? (It could be worn on the top or the bottom.) I do not think that there is a spec for that. Perhaps an inspection will reveal much greater free travel for one of the rockers.
S1000RR
Dec 5, 2012 11:01 PM
ronqqq
Sep 26, 2006 07:32 AM
blackhatchb20
11
Jul 1, 2006 11:43 AM
sbcs15
Sep 6, 2005 05:42 AM
