valves loose>?
Old Mar 8, 2006 | 11:06 AM
88crxdxfastwhip's Avatar
Default valves loose>?
sup guys i have2 crxs 1 dx 1 hf both have valve issues i set them both becuase the valves sounded loose .Now on the dx im swaping with a b18 so im not worried about that but my hf has the 1.6 sohc and i wanna kepp it but the valves keep getting loose any answers to this problem its pissing me off evertime i get them tight they get loose in a few days !!! anyone else have this problem??
Old Mar 8, 2006 | 11:39 AM
TapOrSnap's Avatar
Default Re: valves loose>? (88crxdxfastwhip)
How can you tell if your valves are loose?
Old Mar 11, 2006 | 12:30 PM
SkeeRX's Avatar
the rocker arms make a lot of noise.. make sure you're torquing those bolts to spec.. that could cause them to come loose
Old Mar 11, 2006 | 03:04 PM
payneth's Avatar
Default Re: (Team Teal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team Teal &raquo;</TD></TR><TR><TD CLASS="quote">the rocker arms make a lot of noise.. make sure you're torquing those bolts to spec.. that could cause them to come loose</TD></TR></TABLE>
yeah like he said. make sure you are torquing them down to specs. And make sure to double check the lash after you complete the adjustment just to make sure everything is in spec. Then go around and make sure everything is torqued a second time just because it's always good to double check!
Old Mar 13, 2006 | 10:46 AM
Default Re: (payneth)
aight thanks guys i ll try agian
laboyon
Aug 14, 2008 05:08 PM
Spoonsinglecam
13
Jan 25, 2008 04:22 PM
ITR-00-1457
Mar 29, 2006 09:38 AM
VTECcnIT
Nov 7, 2005 01:17 AM
projectEK9
10
Jun 28, 2003 06:24 PM
