Honda S2000 Honda S2000
need help with latches
Old Mar 8, 2006 | 10:27 AM
raulmenjivar9's Avatar
Default need help with latches
i just bought a s2000 andthe top wasent closing right i when to the dealer and they told me they would charge me 296dollars to fix it any help?
Old Mar 8, 2006 | 11:13 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: need help with latches (raulmenjivar9)
Give a better explanation than "wasn't closing right". Pictures will help.
Old Mar 8, 2006 | 05:48 PM
Default Re: need help with latches (Slideways2000)
well it closes good but when i hit about 70mph it sounds really loud in side like its not closing right
Old Mar 8, 2006 | 05:50 PM
Nishant's Avatar
did the dealer tell you what they were gonna fix?
Old Mar 8, 2006 | 09:13 PM
* B A N N E D *
For $296 they're just going to shim/adjust your catchers. New ones + labor run much more than that.
Old Mar 9, 2006 | 06:14 AM
2000S2000Mike's Avatar
I have the same problem, and I too took it to the dealer. They said the adustments aren't in the hooks (they said that there's no adjustment there and I agree), but in the back where the top supports are. I didn't get a price and let it go at that. This is, again, what the dealer-service dept. said and they've been good with me on the work I've had done. But, if anyone else has anymore info. on this topic, I'd like to know too!
Old Mar 9, 2006 | 06:59 AM
p nut's Avatar
Does the noise go away if you grab hold of the handle for the top and pull down? I had that problem, so I took some rubber tubing and slid them over the little hooks on the latch. Works good, so far.
Old Mar 9, 2006 | 08:01 AM
Default Re: (P Nut)
thats exactly what happends if i hold it down it stops
Old Mar 9, 2006 | 11:33 AM
AdamQ3B85's Avatar
Default Re: (raulmenjivar9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raulmenjivar9 &raquo;</TD></TR><TR><TD CLASS="quote">thats exactly what happends if i hold it down it stops </TD></TR></TABLE>
What year is your s2000?
Old Mar 9, 2006 | 11:42 AM
Default Re: (AdamQ3B85)
2000
nofrenfish
Honda S2000
15
Feb 18, 2010 01:47 PM
B18c1vicrx
Honda S2000
Oct 4, 2006 02:10 PM
Nishant
Jun 20, 2003 05:58 PM
EFing8
Feb 28, 2003 03:19 PM
