How to close my sunroof with the wiring harness removed? 1989 CRX
Old Mar 8, 2006 | 04:13 AM
djnikko's Avatar
Default How to close my sunroof with the wiring harness removed? 1989 CRX
So Ive got everything ready on my car for an engine conversion and was about to ring the shop to arrange to book it in however I noticed my sunroof is open a notch from where I was messing with sticking the seal back on. Can I just run a positive and negative wire from the battery to the sunroof switch and give it a flick?
Any ideas would be appreciated
Old Mar 8, 2006 | 04:20 AM
Autoworks's Avatar
Default Re: How to close my sunroof with the wiring harness removed? 1989 CRX (djnikko)
Can't you crank it by hand with an allen wrench? I havn't been in my car in a while, but I know my brothers DA has a slot in the ceiling that lets you close the sunroof manually in case it for some reason stops working
Old Mar 8, 2006 | 05:45 AM
djnikko's Avatar
Default Re: How to close my sunroof with the wiring harness removed? 1989 CRX (Autoworks)
Im pretty sure you can I dont know why I didnt think of that before, I think its the same for the windows. I'll check my workshop manual im sure they'll tell me how, unless someone can tell me here before I get home to have a look.
Thanks
Old Mar 8, 2006 | 05:50 AM
crx_88_si's Avatar
ya right infront of the dome light there's a little plastic cap. remove that and you'll see a crank torx head. In with the spare tire and jack should be the handle to spin it.
Old Mar 8, 2006 | 07:38 AM
djnikko's Avatar
Default Re: (crx_88_si)
I always wondered what help that tool will be when changing a tyre, turns out its for the sunroof eh! Thanks guys
Old Mar 8, 2006 | 07:51 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">ya right infront of the dome light there's a little plastic cap. remove that and you'll see a crank torx head. In with the spare tire and jack should be the handle to spin it.</TD></TR></TABLE>
I knew it was something like that
Old Mar 9, 2006 | 11:58 AM
djnikko's Avatar
Default Re: (Autoworks)
It worked a treat
honda_lx
May 20, 2014 10:45 AM
Phyreangel
Aug 29, 2007 07:10 AM
Catch 22
Jan 25, 2006 05:59 AM
Steve91
Oct 24, 2003 12:45 PM
curiousgpnoy
Apr 5, 2002 11:58 AM
