jdm headlights?
88-89 jdm have the same headlights as usdm
90-91 ef6, ef7, ef8 all have the same front, the headlights are different as the are slightly longer. ie the bonnet bit is narrower in the middle
All jdm lights are plastic.
UKDM Lights are Glass
be more specific about wat year you want then i can halp you out. It was already said ill reapeat though: jdm plastic, usdm glass, 88-89 jdm same shape, 90-91 are not the same shape thus u would need the rest of the fron end for them to fight correctly
"ZC" 16V headlight. Single beam/single bulb. Fits USDM
VT headlight. Same as SiR, only H4 and glass.
OK, it's not a fair comparison, because the top ones are single beam too.
But they are the same shape as a USDM set and will bolt right in.
Modified by SETI20 at 3:57 PM 3/9/2006
sir ones wont fit unless yu do the whole converison. you can get ones that fit they usually list them as ZC lights, they are plastic and same size as US and have 1 bulb that looks like a weird H4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">jdm ef7? or ef8?
ef7 are the same as usdm but plastic i believe
the ef8 sir stick out an inch farther foward than usdm</TD></TR></TABLE>
arent ef7 ,ef8 etc. only single bulb? sumone correct me if i am wrong???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote"> sir ones wont fit unless yu do the whole converison. you can get ones that fit they usually list them as ZC lights, they are plastic and same size as US and have 1 bulb that looks like a weird H4</TD></TR></TABLE>
My headlights that I posted are glass, and they use a regular H4 bulb.
They'll bolt in without any body modding. You might need to rewire a little, but the plugs etc are included.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryhound »</TD></TR><TR><TD CLASS="quote">
1992 siR JDM headlights.</TD></TR></TABLE>
Sorry for being jackass. But CRX's were never made at 1992. So its just 1991 model registered in 1992. Someone can get confused.
Nice color tho.
Nice color tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight »</TD></TR><TR><TD CLASS="quote">
Nice color tho.
From the JDM catalogs I have seen, the CRX was made from 88-92 everywhere but the USA.
Nice color tho.
</TD></TR></TABLE>From the JDM catalogs I have seen, the CRX was made from 88-92 everywhere but the USA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo »</TD></TR><TR><TD CLASS="quote">
From the JDM catalogs I have seen, the CRX was made from 88-92 everywhere but the USA.</TD></TR></TABLE>
I'm 80% sure that the chassis code never had S4 in the line. I've never heard that they have been produced in the 1992. Look at your VIN tags, there certainly doesent read JHMEF8XXXXS4(!)XXXX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryhound »</TD></TR><TR><TD CLASS="quote">Twilight -
In the UK we have EE-F8 CRX's registered in 1993!
And yes mine is a 1992 JDM siR
Just check out the VIN#. You'll see it's -registered- and not -built- in that year.
Still tho. Means less miles and less weathering if it's sitting in a showroom.
</TD></TR></TABLE>Just check out the VIN#. You'll see it's -registered- and not -built- in that year.
And yes mine is a 1992 JDM siR </TD></TR></TABLE>
Yeah. REGISTERED, but never made at that year. Like my friend SETI20 said, they have been storaged till 1992. Check for your VIN tag, no S4 in the line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 »</TD></TR><TR><TD CLASS="quote">Ok, so teh 1nt3rnet said so right?
SHow me the VIN#...</TD></TR></TABLE>
yep
yep
Glass ones come from Europe, plastic ones come from Japan.
The ones I posted are glass.
Unless youmean the headlights that have the corners integrated. These are usually from the sedan sold mainly in Japan.
