Does anyone use Redline synthetic Tranny fluid?
Old Mar 31, 2002 | 09:10 AM
Thasty's Avatar
Default Does anyone use Redline synthetic Tranny fluid?
Im going to order this miracle fluid, just wondering if anyone has used it in there GSR's?
Old Mar 31, 2002 | 10:12 AM
slowerthanu's Avatar
New User
Default Re: Does anyone use Redline synthetic Tranny fluid? (OnlyNod)
I do not reccomend this, I did it on my First tranny and It went to ****, I only use honda MTL, this supposed magic fluid is not specifically designed for Hondas. All this coming from a fan of Redline fluids.
Old Mar 31, 2002 | 12:10 PM
Thasty's Avatar
Default Re: Does anyone use Redline synthetic Tranny fluid? (slowerthanu)
Really? I dumped this stuff into my 89 supra turbo and 90 300ZXTT, took away the grinding in 4th and 5th gear. Any reason that it wouldn't work well? good thing i asked/
JDMgsr93's Avatar
I agree stick with OEM Honda fluids. I used redline fluids in my 91 hatch w/B16 swap. My tranny started grinding while shifting gears after a while.
Old Mar 31, 2002 | 12:29 PM
frostwhite_92's Avatar
I have used Red Line MTL in 4 of my Hondas and in over 10 of my friends'.
It works fine.
Old Mar 31, 2002 | 12:35 PM
lilblacksol's Avatar
Default Re: Does anyone use Redline synthetic Tranny fluid? (frostwhite_92)
i havent heard anything bad about it yet....me and a couple of my friends run it
Old Mar 31, 2002 | 02:03 PM
Regular Series's Avatar
Works just ducky in my RS, but I've only had it for a few hundred miles. Make sure you get MTL, NOT MT-90! MTL is the proper fluid for a late-model Honda tranny.
Old Mar 31, 2002 | 04:52 PM
Thasty's Avatar
Default Re: Does anyone use Redline synthetic Tranny fluid? (risingson77)
Where did you hear about the MT90 part? I looked on Redlines website, you were right about the MTL being used in newer trans that have to meet a certain regulation. If anyone is interested.... http://www.redlineoil.com/frames/mtlti.htm
[Modified by OnlyNod, 8:53 PM 3/31/2002]
Old Mar 31, 2002 | 05:46 PM
Another poster on H-T (forgot their handle ). If you read your owner's manual it talks specifically about using GL-4 lube. It's a touch lighter than a GL-5 fluid (such as MT-90 and Mobil 1) and has different friction modifiers for the synchronizers. MTL meets the GL-4 specification.
Old Apr 1, 2002 | 10:04 PM
blacksheep's Avatar
I'm happy with it!
Old Apr 1, 2002 | 10:12 PM
rodimus's Avatar
Default Re: Does anyone use Redline synthetic Tranny fluid? (blacksheep)
i would be an ******* and say search and blah blah...
but oh well..
this topic has been covered many times...it's coo tho...
synthetic doesn't allow your synchros to operate properly...
honda MTL has additives the tranny NEEDS....
also GM synchromesh works very very well i hear.
Old Apr 2, 2002 | 12:24 AM
Default Re: Does anyone use Redline synthetic Tranny fluid? (EVOL)
thankx for the info EVOL
Old Apr 2, 2002 | 05:04 AM
Thasty's Avatar
Thanks everyone for the help. By the way if you haven't noticed the search function is down.
Old Apr 2, 2002 | 05:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I just tried a search and it worked just fine.
Honda trannies require a lubricant w/ 10w30 properties. Redline MTL is just such a lubricant. MT-90 is for trannies that require 75w90 gear oil, like many Nissan trannies. Evo was right about the tranny needing friction additives for proper synchro operation. Redline MTL also has this. I have not personally tried it yet, but I don't see how it could possibly be detrimental to the tranny.
Old Apr 2, 2002 | 07:54 AM
bps2799's Avatar
Default Re: Does anyone use Redline synthetic Tranny fluid? (PatrickGSR94)
Try it. If it grinds, you know what to switch back to.
Old Apr 2, 2002 | 07:56 AM
maggsgsr's Avatar
Default Re: Does anyone use Redline synthetic Tranny fluid? (bps2799)
the search is not down,its just they changed us to a different server in which it doesn't contain old threads just recent.
Old Apr 2, 2002 | 07:12 PM
kkim's Avatar
Default Re: Does anyone use Redline synthetic Tranny fluid? (maggsgsr)
In that case, the search is f****d.
I have used Redline fluids in my last 5 cars. No problems to report. Just be sure to use the proper lubricant for the proper application. Honda/Acura trannys use Redline MTL. Works great, shifts smoother, supposed to work better than conventional(dino) oils when it gets cold. I give it a
Old Apr 2, 2002 | 07:16 PM
CivicEx95's Avatar
Default Re: Does anyone use Redline synthetic Tranny fluid? (kkim)
I use it, no problems
Anybody ever think that your tranny starts grinding cause of the abuse it's taken, and not the fluid? I know Civic trannys arent the toughest things out there, and are very well known for grinding from 1st to 2nd. I personally have had two that have done it.
AlekSir
Mar 22, 2005 07:20 AM
mymeatb18"
Dec 31, 2004 06:26 PM
jdmCivic925
Mar 10, 2004 11:06 AM
P1mpSlap
Mar 15, 2003 03:28 PM
EF-9SiR
10
Nov 3, 2002 07:57 AM
