help just relocated battery
i just put a b18a in and relocated my battery to the trunk. i used 4 guage wire for the power and ground.
My problem is it turns over very slow and wont start? I put new grounds on and it cranked a little faster but not normal. It has spark, when i pulled the plugs out after cranking it the are wet with fuel, and it has compression.
Modified by 90crxlst at 7:47 PM 3/7/2006
I doubt the relocation has anything to do with it if you never turned the motor over before the relocation. It sounds more like a motor problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspecs_jamar »</TD></TR><TR><TD CLASS="quote">make sure that your getting good enough spark</TD></TR></TABLE>
How can u tell if it's "good enough".
i got it turning over normal it was a bad battery. But i have spark, fuel, compression and it wont even fire. I just check rechecked the timing belt and it is all on the marks
TheTealHatch
13
Oct 15, 2008 04:02 AM
Tuesdaynightfever
Jun 26, 2005 02:19 PM
