Sellling Completely built H22 motor
I have a 2000 H22a4 that was completely built top to bottom. I was going to swap this to my 01 Accord, but decided to sell everything even the car to start new project. Here is a list of everything done.
2K H22a4 block Darton MID 89mm bore, decked, honed, line honed, etc.
89mm bore JE pistons 9:1
Total Seal gapless rings
Carillo H beam Rods
Factory Bearings/seals/gaskets
Circuit works/pro-drive oil pump gear
Cometic HP gasket
ARP Main/Head Studs
h22 Race Stage HEad port/polish 5 angle valve job
Skunk2 Dual valve springs/Ti retainers
+1mm Skunk2 Valves
Crower turbo cams
STR cam seal
Skunk2 Cam Gears
Greddy Timing/balance Belts
AC Autotechnic Intake Manifold
STR Throttle body 68mm
STR Competition Fuel Rail
PRecision 880cc injectors w/ clips
South Florida Performance Exhaust Manifold (jet hot Coated)
Precision SC-63s cover
Tial 38mm wastegate
TUrbo XS RFL blow off valve
Fidanza Flywheel
RPS Turbo Max Clutch kit
Unorthodox racing pulley set for PS, and Altenator
Seanz Transmission
Motor is entirely Fresh (not started) All specs/clearances are race ready. Motor is capable of over 700+ whp on low boost, possibly 1000+ on high boost and good tune) I have over $19K ($4+ on tranny, $15k+ on motor) Would like to keep it together but understand people's budget may limit to only pieces. Asking $16K for everything, willing to possibly part out, but no low ballers, everything is BRAND NEW.ONLY SERIOUS INQUIRES please don't waste time BSing on the thread.
Modified by 2001accord at 8:37 PM 5/19/2006
Carillo H beam Rods
Cometic HP gasket
ARP Main/Head Studs
+1mm Skunk2 Valves
Crower turbo cams
STR cam seal
Skunk2 Cam Gears
Tial 38mm wastegate
Fidanza Flywheel
Seanz Transmission
All Parts cost $13,530 not including the Block or head!!
Trans $4180 not including LSD new syncros/seals/gear slider hubs/bearings!!!
(sleeves $700, all machining $1400, $2100 total)
89mm bore JE pistons 9:1 $720
Total Seal gapless rings $155
Carillo H beam Rods $650
Factory Bearings/seals/gaskets $250
Circuit works/pro-drive oil pump gear $295
Cometic HP gasket $130
ARP Main/Head Studs $220
h22 Race Stage HEad port/polish 5 angle valve job $2400
Skunk2 Dual valve springs/Ti retainers $230
+1mm Skunk2 Valves $260
Custom grind Crower cams (designed for Turbo Application) $840
STR cam seal $20
Skunk2 Cam Gears $200
Greddy Timing/balance Belts $150
AC Autotechnic Intake Manifold $1150
STR Throttle body 68mm $400
STR Competition Fuel Rail $150
PRecision 880cc injectors w/ clips $375
South Florida Performance Exhaust Manifold (jet hot Coated) $675
Precision SC-63s cover $1045
Tial 38mm wastegate $300
TUrbo XS RFL blow off valve $140
Fidanza Flywheel $210
RPS Turbo Max Clutch kit $465
Unorthodox racing pulley set for PS, and Altenator $300
Seanz Transmission (currently still there being assembled waiting for it to be shipped back) Gearset is $1980, R&P is $2200
STR cam seal $20
2001accord
Apr 8, 2006 10:35 AM
