Should be so easy. But its not !
Old Mar 7, 2006 | 12:12 PM
Paulpenuk's Avatar
Default Should be so easy. But its not !
Have stripped all the trim out of my 91 crx apart from dash (which can wait) but can seem to get the rear view mirror off. The manual says to use a flat blade screwdriver but it wont come off for all the levering in the world
Please help me !
Old Mar 7, 2006 | 12:15 PM
si0385.'s Avatar
Default Re: Should be so easy. But its not ! (Paulpenuk)
if you use a torch and heat up the outside of the window it will come right off.. go to your local glass shop and have them do it though cuz if you havent practiced it a couple of time you will crack your windshield...
i doubt they will charge you anything if they wanna be dicks and charge you it wont be more than 5-10 bucks
Old Mar 7, 2006 | 12:17 PM
Paulpenuk's Avatar
Default Re: Should be so easy. But its not ! (si0385.)
Its not the type that is stuck to the glass its the one with the plastic cover on it (cant get off) and then I assume there are screws on it
Its stopping me removing the head lining
Old Mar 7, 2006 | 12:24 PM
STREETWERKZ's Avatar
slip the flathead into the plastic cap....
should be 3 phillips head screws under that.
(are you trying to PRY the whole thing out of your roof with the screwdriver???)
Old Mar 7, 2006 | 12:25 PM
Paulpenuk's Avatar
Default Re: Should be so easy. But its not ! (STREETWERKZ)
I am doing it under the cap but just wont budge and I dont want to scratch it !
Where is the best area to slip it in ?
Old Mar 7, 2006 | 12:29 PM
si0385.'s Avatar
right behind the red seatbelt lights it comes apart you should be able to see the little split than there are the 3 philips screws behind it
Old Mar 7, 2006 | 12:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paulpenuk &raquo;</TD></TR><TR><TD CLASS="quote">Where is the best area to slip it in ?</TD></TR></TABLE>
No comment.
Old Mar 7, 2006 | 12:33 PM
si0385.'s Avatar
haha pervert
Old Mar 7, 2006 | 12:35 PM
Paulpenuk's Avatar
If only there was a rolleyes smiley
Old Mar 7, 2006 | 12:37 PM
Outsane's Avatar
those cover get broken alot...so if you get frustrated... order a new cover..
and then yank at the rear view mirror...
they are designed to come apart in the event your head fly's at it in an accident..
the mirror section will seperate from #10 in the diagram which will still be stuck to the car, then use a phillips to remove..
Old Mar 7, 2006 | 12:42 PM
Paulpenuk's Avatar
Default Re: Should be so easy. But its not ! (Outsane)
Thanks mate
Back out I go in the dark again
Old Mar 7, 2006 | 12:45 PM
Outsane's Avatar
sure..
here's the part you need to order.
http://www.hondaautomotivepart...IRROR
get me one too!
Old Mar 7, 2006 | 03:12 PM
SlobberGoat's Avatar
I totally mangled #12 when I tried to pry it off.
Old Mar 7, 2006 | 05:58 PM
Outsane's Avatar
Default Re: Should be so easy. But its not ! (SlobberGoat)
ha ha..
atleast they are not too expensive..
Uncle Willie
Apr 25, 2016 08:48 AM
Dkahn18
Jan 3, 2009 09:18 AM
SyDuck
Jun 1, 2005 10:43 PM
neo22ny
Feb 18, 2005 09:03 AM
TrAnCeD_RaCeR
Mar 17, 2004 01:55 PM
