so theres an oil leak
Did you do something to the transmission recently? I’m also having the same problem, but its actually leaking from the seal because I open the tranny and I didn’t use the right silicon/gasket. It might also be leaking from the axel seal if you over fill the gear oil or the axel seal is no good.
