SI Trans in a d15 car
Old Mar 7, 2006 | 04:26 AM
rosstallika's Avatar
Default SI Trans in a d15 car
Im buying a 88/91 si trans and i have a 4 speed d15 hatchback. All that i need to do is buy cv shafts right, if im missing something or i have to do something special can you let me know? I dont have to change linkages or mounts do i?
Old Mar 7, 2006 | 05:09 AM
purplecrx's Avatar
I WAS WRONG.
Modified by purplecrx at 10:15 AM 3/7/2006
Old Mar 7, 2006 | 05:17 AM
dr_latino999's Avatar
Default Re: (purplecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplecrx &raquo;</TD></TR><TR><TD CLASS="quote">I believe you'll have to use Si/DX axles, which will also require the Si/DX knuckles. Linkages and mounts are the same... as far as I know, so check with someone else first.</TD></TR></TABLE> Someone else has arrived!
ITEMS THAT NEED TO BE CHANGED
- Transmission
THINGS THAT ARE THE SAME
- Axles (As long as you retain your stock hubs)
- Hubs (As long as you retain your stock axles)
- Shift Linkage (Unless you forget to bolt it on all the way and it falls off, it then may be a little shorter and you may want to change it )
THE END
Have a beer, enjoy five speed goodness (not at the same time) and all will be well.
Old Mar 7, 2006 | 05:18 AM
crxnj's Avatar
Default Re: SI Trans in a d15 car (rosstallika)
Actually you can use the 4 spd axles as long as you keep the 4 spd hubs..The inner joint on all those axles is all the same,,its the outer thats different..STD/HF being smaller then the rest..
Dr.latino beat me..
Old Mar 7, 2006 | 06:11 AM
Crimson_Tide's Avatar
Default Re: SI Trans in a d15 car (Mr.speaker)
^^Corrrrrrect!! im tired of people saying you cant use std axles with an si tranny... just make sure that if your motor is 89 and up that you get a transmission that is also 89-91... 88 has 21 splines on the input shaft while 89-91 have 20 i believe... good luck!!
-Josh
Old Mar 7, 2006 | 06:15 AM
purplecrx's Avatar
Well I got sucked up into the urban legend. Always hear people talking about changing hubs/axles. I'll edit out my post! Thanks guys.
Old Mar 7, 2006 | 06:57 AM
np bro
-Josh
Old Mar 7, 2006 | 08:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Actually you can use the 4 spd axles as long as you keep the 4 spd hubs..The inner joint on all those axles is all the same,,its the outer thats different..STD/HF being smaller then the rest..
Dr.latino beat me..</TD></TR></TABLE> Latino FTW!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide &raquo;</TD></TR><TR><TD CLASS="quote">^^Corrrrrrect!! im tired of people saying you cant use std axles with an si tranny... just make sure that if your motor is 89 and up that you get a transmission that is also 89-91... 88 has 21 splines on the input shaft while 89-91 have 20 i believe... good luck!!
-Josh</TD></TR></TABLE> It's something like that, also if you do end up with miss-matched splines there are some creative clutch combinations that will work in your favor
Old Mar 7, 2006 | 09:44 AM
Default Re: SI Trans in a d15 car (dr_latino999)
yeah but why go through the hassle if your clutch is good? unless you can get a crazy deal on an '88 transmission and you want a clutch disc to throw at a car when youre driving down the road
-Josh
Old Mar 7, 2006 | 10:41 AM
Default Re: SI Trans in a d15 car (dEaF_HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRIMSON TIDE DAMN IT! &raquo;</TD></TR><TR><TD CLASS="quote">yeah but why go through the hassle if your clutch is good? unless you can get a crazy deal on an '88 transmission and you want a clutch disc to throw at a car when youre driving down the road
-Josh</TD></TR></TABLE> I liked Crimson Tide better, it stood out amongst the crowd Now how the hell am I supposed to remember this new name? Consideration for others! And FYI I have thrown a clutch disc at a car while driving, it makes you feel better inside.
Old Mar 7, 2006 | 11:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> I liked Crimson Tide better, it stood out amongst the crowd Now how the hell am I supposed to remember this new name? Consideration for others!</TD></TR></TABLE>
ehh it was time for a change... plus this is my username on all the other sites... im just going to test this one out on here and see how it goes lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">And FYI I have thrown a clutch disc at a car while driving, it makes you feel better inside.</TD></TR></TABLE>
yeah you gave me that idea when i was going to get that transmission off of you and you offered me a free clutch disk with it... i told you that i just bought a new clutch and you said i could be like you and throw it at other cars on the highway lmao
Old Mar 7, 2006 | 11:09 AM
btgw i got this username after running around lima with open header for about a month
-Josh
Old Mar 7, 2006 | 12:16 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dEaF_HATCH &raquo;</TD></TR><TR><TD CLASS="quote">^^Corrrrrrect!! im tired of people saying you cant use std axles with an si tranny... just make sure that if your motor is 89 and up that you get a transmission that is also 89-91... 88 has 21 splines on the input shaft while 89-91 have 20 i believe... good luck!!
GsrTurboCRX88
Feb 19, 2007 02:52 AM
CRseXy
Dec 14, 2004 10:26 PM
Red_Si
11
Dec 21, 2003 09:54 PM
** OF HAZARD
Nov 13, 2003 12:17 PM
1CiViC1
Jun 21, 2003 10:39 PM
