disc bracke conversion
Old Mar 7, 2006 | 02:41 AM
clarkcw's Avatar
Default disc bracke conversion
Is their a way to convert 05 civic sedan to rear disc from drums
Old Mar 7, 2006 | 07:47 AM
blouisgod's Avatar
02/03 si hubs, rotors, calipers, brake hose, ebrake cables. make sure its 4 bolt, the ep3 has a 5 bolt version out also (04/04 i think)
Old Mar 7, 2006 | 08:57 AM
clarkcw's Avatar
Default Re: (blouisgod)
thanks for the advise, but I just want to clarify that I can take order these parts and they will work and what do you mean with make sure it is 4 bolts.
Modified by clarkcw at 10:25 AM 3/7/2006
Old Mar 7, 2006 | 12:35 PM
skipbarber's Avatar
he meant 4 lug. the later ep3's went with 5 lug. you need the brake assemblies from the earlier ep3's.
Old Mar 7, 2006 | 12:49 PM
clarkcw's Avatar
Default Re: (skipbarber)
Do I need to change both front and rear or just rear. and is the Master cylinder included in that.
Old Mar 7, 2006 | 12:54 PM
cmdr430's Avatar
Default Re: disc bracke conversion (clarkcw)
what is the car being used for?
do you do hpde's, auto x, etc?
what is the need to convert the rear to disc?
Old Mar 7, 2006 | 01:03 PM
mrDFWmechanic's Avatar
you just change the rear
Old Mar 7, 2006 | 01:48 PM
Boilermaker1's Avatar
Default Re: disc bracke conversion (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">what is the car being used for?
what is the need to convert the rear to disc?</TD></TR></TABLE>
I'm sure there is no need beyond it "looks cool"
You can take the car on the track with drums (they're actually lighter), problem is they don't cool off and it kills the shoes way too quickly.
Only reason I swapped them is that the pads are easier to change than the shoes are, especially when killing them as quickly as lapping days do. The discs also seem to at least stay cool enough to not kill pads (more than likely its the fact that I can use Non-Honda pads that are intended for high temps).
Hot day + heavy car + track with a lot of braking is not going to be kind to the drums, but short of that, there's no valid reason to change them.... the car's got a 5:1 bias to the fronts anyways.
Old Mar 7, 2006 | 08:45 PM
clarkcw's Avatar
Default Re: disc bracke conversion (Boilermaker1)
The reason for doing it is to learn more. The only mods I normaly do are sound systems, interior/exterior lighting. Do I need to change the master cylinder or is the one I've got fine. Thanks for the help and advise if you have anymore please let me know.
Old Mar 8, 2006 | 07:46 AM
skipbarber's Avatar
the one you have is fine, the hardest part is getting the e-brake cables to work. which isnt that hard at all. make sure you do a full bleed of your lines when youre donw.
Old Mar 8, 2006 | 09:23 AM
clarkcw's Avatar
I looked into it and was wondering if I should use the parts form the 05 SI instead of an 02/03 to do the conversion sense the rear lower arm knuckle part numbers match for the 05 SI and the 05 sedan.
Old Mar 8, 2006 | 09:59 AM
fventura03's Avatar
Default Re: (clarkcw)
use 02/03 parts, 04+ is 5lug, it'll work, but you'd have 4 lug in front, 5 lug in rears...
Old Mar 8, 2006 | 11:06 AM
clarkcw's Avatar
Default Re: (fventura03)
what other mods should I look into.
Mugen Project
Honda Civic (2001 - 2005)
Jul 27, 2007 03:02 AM
duyfash0
Apr 15, 2007 11:46 AM
joey_06_2004
Apr 4, 2007 10:25 AM
jdm94accord
May 4, 2006 09:21 AM
eg:R
Jan 29, 2006 06:50 PM
