S1 trans for turbo
Im building a B16 turbo, and going for 500hp. Ive blew a gen 1 b16 trans which was a s1 (na). I think it was bad luck. My question is would it hold the power. Im planning on using an lsd not sure on which one yet, act extreme clutch, and stage 5 axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback »</TD></TR><TR><TD CLASS="quote">Just use the b16 trans and adjust your gearing using different sized slicks.
Amen
LS =
IF you are trapping to high for a b16 with huge slicks step to a GSR.
</TD></TR></TABLE>Amen
LS =
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C »</TD></TR><TR><TD CLASS="quote">You'd be happier with a cable LS.
What makes you even say such a thing?
</TD></TR></TABLE>What makes you even say such a thing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">What makes you even say such a thing?</TD></TR></TABLE>
You'll stay in boost longer.. hell, I ran faster at the track NA with an LS tranny.
13.3@99 w/190whp
B16 1st gear sucks if you have a lot of power IMO
13.3@99 w/190whp
You'll stay in boost longer.. </TD></TR></TABLE>
Oh god I can't wait till someone who has the willpower to post it gets to this.
So for a turbo car in your theory I should run a 2 gear setup one true 1:1 ratio and a shorter gear to get into boost for uber fast cause id be aways in mad boost y011!!1
expletive i'm sleepy.
If you can't get traction get slicks or do suspension work.
Shorter gears > longer gears its that simple.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C »</TD></TR><TR><TD CLASS="quote">You'll stay in boost longer.. hell, I ran faster at the track NA with an LS tranny.
13.3@99 w/190whp
B16 1st gear sucks if you have a lot of power IMO</TD></TR></TABLE> Jeff Evans disproved this - http://forums.evans-tuning.com...=1496
13.3@99 w/190whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote"> Jeff Evans disproved this - http://forums.evans-tuning.com...=1496</TD></TR></TABLE>
*bows to Jeff*
I couldn't find it but I knew it was out there.
*bows to Jeff*
wow, Cable LS isn't as bad as everybody thinks.. It has the same final drive as the Cable B16 tranny.. Don't get that Cable LS confused with the hydro LS that has the tallest gears of them all.
For a 500whp street driven car, 1st-3rd would be useless with a cable B16 S1 IMO
