coolant level dropping every week... no leaks?
hey guys
About 2-3 weeks ago, i replaced a cracked radiator in my civic. Everything went pretty well. However for the past few weeks ive been keeping a pretty close watch on the coolant levels, and it always seems like the fluid in the reservoir is low. I know for a fact that im not leaking any in the garage. And my headgasket seems fine, my oil doesn’t look milkyish or any of that good stuff. Where has my coolant gone?
Could it just be the hoses and its age? Or has the coolant not been fully flushed through the system?
thanks ek
thanks ek
either gremlins or lepricons.
no i kid, try make sure u arent leaking. also u may still have air bubbles in your coolng system, which is being replaced with coolant and its coming from the resavoir. (sp?) i would maybe keep adding, running the engine and checking levels again until it either shows a determined leak or fills properly.
have you noticed any smoke coming out the exhaust?..when you have a leak in your system and its not external then it has to be internal ex. like a blown head gasket. and if it has been over heating on you that maybe another sign its a head gasket. or it could be air in the system(hopefully)
91civicsikid
13
Jun 24, 2014 03:23 PM
