Which ECU do i have? Tips on chipping??
Old Mar 6, 2006 | 06:33 PM
ella94's Avatar
Default Which ECU do i have? Tips on chipping??
Hello. Im new here to Honda-Tech. Although have been reading for some time, only just recently registered.
My question is how can i tell what ecu i got? My old motor was a d16z6 equiped with a p28, almost 100% positive on that.
My b16 swap came with a p30 (?) not to sure. Was going to have the ecu that came with the swap chiped. Would clean up some of the problems the ecu has, such as random sensor errors. A code 9, which i looked up was a cyclinder pressure error, came up on the b16 but not the old d16 ecu. Friend of mine told me it didnt really matter which one got chiped, but is there a difference? Help me out Not very good with this computer tuning and junk, but trying to learn.
Thanks much
Old Mar 6, 2006 | 06:35 PM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: Which ECU do i have? Tips on chipping?? (ella94)
as long as your swap was wired right, then the p30 should work fine
Old Mar 6, 2006 | 06:37 PM
ella94's Avatar
Default Re: Which ECU do i have? Tips on chipping?? (honda 3300)
But that doesnt explain why my old d16z ecu works without engine light coming on and the new p30 ecu always comes on with a cyc. pressure error. Anyone got some thoughts?
Old Mar 7, 2006 | 03:35 PM
R.I.P.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ella94 &raquo;</TD></TR><TR><TD CLASS="quote">But that doesnt explain why my old d16z ecu works without engine light coming on and the new p30 ecu always comes on with a cyc. pressure error. Anyone got some thoughts?</TD></TR></TABLE>like i said, if it was wired right
Old Mar 7, 2006 | 04:25 PM
743power's Avatar
No it doesn't, but every mpfi ef, eg, ek, and dc has one. It's inside the distributor, and it's not the "cylinder pressure sensor," it's the cylinder postion sensor.
If you have access to another obd1 vtec distributor, try swapping them and see if it throws the code.
As far as chipping goes, they can both be chipped. The p30 is generally going to be worth more money than the p28, unchipped. So if you chip the p28, you can sell the p30 for more $$$.
Old Mar 7, 2006 | 04:33 PM
fmrprojects's Avatar
Default Re: Which ECU do i have? Tips on chipping?? (743power)
imma have to say that the p30 ecu is messed up maybe beacause if you get the code for 1, you should get it with another. get the p28 chipped and you be good to go
Old Mar 7, 2006 | 05:24 PM
elguluso's Avatar
the P28 is the staple of chipping gods everywhere, plus like they told you before, the p30 is worth more $$$ if you sell it unchipped, change the dizzy or check your wiring, trust what came with your swap.
mita
Aug 28, 2014 11:46 PM
Big Si Guy
Dec 30, 2003 07:18 AM
eL
Jul 29, 2003 01:24 AM
civichopeful
Mar 27, 2003 04:05 PM
civichopeful
Mar 27, 2003 03:38 PM
