2 plugs on the back of my motor
when i was tucking my wires there are 2 plugs i removed one is easy to get back on, except there is like 2 seperate wires with plugs on the end, which one goes where.
also the other one when i was pulling on it, it came out of the rubber thing, but it was just the wire with no plug. what sensor is that? it is a yellow/red wire IIRC.
91 hf stock motor
thanks
91 hf stock motor
thanks
yellow/red is oil pressure - right by the oil filter
the other one is probably the cooling fan switch - yellow/green and black wires - doesn't matter which wire is on which pin - it is just a switch
j_the_guy
Mar 10, 2019 11:33 PM
BbOi0420
Dec 12, 2014 04:40 PM
