Trunk issue, need help.
Old Mar 6, 2006 | 04:41 PM
00ekcoupe's Avatar
Default Trunk issue, need help.
Ever since I got my car back from the bodyshop (rear-ended) there's been something wrong with my trunk. When I use the driver side latch, sometimes the trunk will stay in the open position and won't close, then I'd have to slam the trunk close. For those with coupes, when you pop the trunk open it literally "pops" and is very light and has a "spring-like" system, and you would barely have to close it hard at all. Now mine just pops but it doesn't swing up like normal. Can anyone help me fix this?
Old Mar 6, 2006 | 05:19 PM
EGchicSOHC's Avatar
Default Re: Trunk issue, need help. (00ekcoupe)
make sure that the striker on the trunk lid is making good contact with the latch. the latch should move easily. also there should be adjusters on the trunk lid to adjust the contact with the body
Old Mar 6, 2006 | 05:44 PM
gixer00's Avatar
MAKE SURE THAT THE LOCK IS LINED UP WITH THE STRIKER AND ALSO CHECK TO SEE IF THEY PUT THE SPRINGS IN THE TRUNK CUASE SOME TIMES WHEN BODYSHOPS CHANGE THE TRUNKS THEY DONT PUT THE SPRINGS IN RIGHT. I WOULD TAKE IT BACK TO THE BODYSHOP AND TELL THEM THAT THE TRUNK DOSENT WORK RIGHT AND YOU WANT THEM TO FIX IT
Old Mar 6, 2006 | 06:39 PM
TurboLaxx's Avatar
Default Re: (gixer00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gixer00 &raquo;</TD></TR><TR><TD CLASS="quote">MAKE SURE THAT THE LOCK IS LINED UP WITH THE STRIKER AND ALSO CHECK TO SEE IF THEY PUT THE SPRINGS IN THE TRUNK CUASE SOME TIMES WHEN BODYSHOPS CHANGE THE TRUNKS THEY DONT PUT THE SPRINGS IN RIGHT. I WOULD TAKE IT BACK TO THE BODYSHOP AND TELL THEM THAT THE TRUNK DOSENT WORK RIGHT AND YOU WANT THEM TO FIX IT</TD></TR></TABLE>
TURN OFF CAPSLOCK!!!
I read this like you're yelling at me....****. Calm down and please dont do all caps again.
IROCKCIVICS
Honda Civic (2001 - 2005)
Jul 18, 2008 10:38 PM
RH-DTeg
Mar 7, 2006 05:25 PM
vg7z
18
Feb 24, 2005 09:10 PM
hob4G
Jun 30, 2004 07:00 AM
96 SOHC VTEC
Jan 8, 2003 02:01 PM
