use the same tranny?
Old Mar 6, 2006 | 04:32 PM
hoeslayer2482's Avatar
Default use the same tranny?
i have a 95' dx i want to put a b16 dohc can i use the same tranny and what elese will i need?
Old Mar 6, 2006 | 04:34 PM
dreww..'s Avatar
you will need the full swap....motor, tranny, ecu, linkage, axles, etc.
BlueIntegraBoy's Avatar
Default Re: use the same tranny? (hoeslayer2482)
You need the B16 longblock with tranny, ECU, axles, and shift linkage. You can use your stock harness but will need to wire up VTEC solenoid, oil pressure switch, and knock sensor.
Old Mar 6, 2006 | 04:39 PM
professor poon's Avatar
you need my B18C swap
JsSIR
May 6, 2009 12:34 PM
dasistheone
Oct 28, 2005 10:03 AM
JBBNJ609
Nov 13, 2003 07:32 PM
hatchmonkey92
Nov 12, 2003 06:25 PM
