Anyone know of a strong glue that drys clear ?
Old Mar 6, 2006 | 03:42 PM
RCautoworks's Avatar
Default Anyone know of a strong glue that drys clear ?
Does not have to be glue, it could be some type of epoxy it just has to dry clear. Any ideas ?
Old Mar 6, 2006 | 03:45 PM
Default Re: Anyone know of a strong glue that drys clear ? (90blackcrx)
Came across this but its a little to much.... $70 bucks
http://www.coolchem.com
Here is the product
And here is the activator
And here is the debonder, just incase you get it on your skin or if you want to debond something.
Old Mar 6, 2006 | 03:51 PM
Dragline's Avatar
Old Mar 6, 2006 | 03:55 PM
Default Re: Anyone know of a strong glue that drys clear ? (Dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dragline &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Old Mar 6, 2006 | 03:59 PM
ALL IMPORT's Avatar
i use a glue with that applying system & it has alot of strenght. & all glues of this typ are $$$
Old Mar 6, 2006 | 04:01 PM
Going to give this a try
Old Mar 6, 2006 | 04:12 PM
MichaelPal's Avatar
what are u bonding together/sealing/glueing?
Old Mar 6, 2006 | 04:23 PM
nitrofish420's Avatar
3M duramix is amazing ****, but it dries a whitish color.
Old Mar 6, 2006 | 04:40 PM
simike's Avatar
Default Re: Anyone know of a strong glue that drys clear ? (MichaelPal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MichaelPal &raquo;</TD></TR><TR><TD CLASS="quote">what are u bonding together/sealing/glueing?</TD></TR></TABLE>
Old Mar 6, 2006 | 05:02 PM
Niles's Avatar
Devcon 2 ton crystal clear epoxy, you can get it in anything from the 9oz bottles I keep on my desk to the gallon buckets with the measuring pumps. Cheap and effective.
Sets in 30 minutes. the bottels say "s-33" on them if that helps you look them up.
If you put your part in a sealed box and pull a vaccum it will dry even more clear because that will pull the bubbles out. It doesn't neccesarily have to be bagged.
Old Mar 6, 2006 | 06:14 PM
.RTErnie's Avatar
Default Re: Anyone know of a strong glue that drys clear ? (Niles)
super glue y0! maybe some elmers. Or start flashing money in a club and then collect the stuff that forms between you and the girls that start flocking to you...that **** is hardcore!
Old Mar 6, 2006 | 06:54 PM
Urethane
Old Mar 6, 2006 | 07:04 PM
blueoval557's Avatar
From my good old days in the hobby of R/C stuff. This stuff is badass, and you WILL not get it apart once its cured. Although...I am not sure on Urethane...itmay only work on wood, but not sure.
http://www2.towerhobbies.com/c...&P=ML
Kyle
P.S. You can get it from a local shop, so you dont have to pay shipping...check your phone book for hobby shops, they'll have it.
Old Mar 6, 2006 | 07:07 PM
Default Re: Anyone know of a strong glue that drys clear ? (blueoval557)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueoval557 &raquo;</TD></TR><TR><TD CLASS="quote">From my good old days in the hobby of R/C stuff. This stuff is badass, and you WILL not get it apart once its cured. Although...I am not sure on Urethane...itmay only work on wood, but not sure.
Kyle
Thanks
Old Mar 8, 2006 | 07:55 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
CA/cyonocralate...look for it in hobby shops.
Old Mar 9, 2006 | 11:24 AM
Chase's Avatar
Default Re: Anyone know of a strong glue that drys clear ? (not so civic)
i hope you dont mind if i jack ur thread, 90blackcrx, but does anyone know of glues that could glue the radiator neck thing back on. My jdm radiator's one broke off
Old Mar 10, 2006 | 11:45 AM
Default Re: Anyone know of a strong glue that drys clear ? (EF8kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid &raquo;</TD></TR><TR><TD CLASS="quote">i hope you dont mind if i jack ur thread, 90blackcrx, but does anyone know of glues that could glue the radiator neck thing back on. My jdm radiator's one broke off </TD></TR></TABLE>
Jbweld, or the stuff I posted up above.
chrismugenracer
Southern California
Feb 11, 2008 09:41 AM
Del Scott
Apr 9, 2006 04:30 PM
mospeed
Jan 12, 2006 09:21 AM
xdude
Feb 7, 2005 07:03 AM
