Full cage and gauges????
Old Mar 6, 2006 | 03:21 PM
underpressure02's Avatar
Default Full cage and gauges????
Those of you with a full 10 point cage running a stock dash where do you mount all of your gauges?
I had pillar bar before with two gauges and my tach mounted there. Then I mounted the rest of them in my center consol, with my wideband on the steering colum. Now with the cage I loose the pillar bar. Trying to figure out where to mount all these gauges. I looked into the autometer mounting stuff that bolts to the cage but it is pretty pricy for what appears to be just a clamp.
If you have some pics of a nice setup post them up.
Thanks
Old Mar 6, 2006 | 03:27 PM
Turbo-charged's Avatar
Default Re: Full cage and gauges???? (underpressure02)
gauges...pffftt...just wing it
i had mine moutned where the radio was last year.......not sure what im going to do this year, they need to all be close together to surve a purpose...you cant watch the tach on the left and gauges on the right. ive seen people put gauges in some stupid places.
im no help!
Old Mar 6, 2006 | 04:01 PM
1FSTHATCH's Avatar
who needs guages...just get a datalogger...
Old Mar 6, 2006 | 04:25 PM
vaporboy12's Avatar
Default Re: (1FSTHATCH)
doesnt someone make cage mount pods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1FSTHATCH &raquo;</TD></TR><TR><TD CLASS="quote">who needs guages...just get a datalogger...</TD></TR></TABLE>
i like to know where my oil pressure is so if something happens i dont rip a motor to pieces
Old Mar 6, 2006 | 04:29 PM
NaIsGay's Avatar
Default Re: (vaporboy12)
they sell gauge pods that mount to the roll bar... pretty nifty.. check summit
i dont remeber them being to pricy tho
Old Mar 6, 2006 | 04:40 PM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">doesnt someone make cage mount pods
i like to know where my oil pressure is so if something happens i dont rip a motor to pieces</TD></TR></TABLE>
With motec it can shut it down for you.
Old Mar 6, 2006 | 04:41 PM
Boner_Ben's Avatar
Most important guage I put on the steering column. You could fit up to 2 guages on the coulumn.
Old Mar 6, 2006 | 04:51 PM
Default Re: (Arturbo)
i have an oil pressure warning light bigger than my turbo
Old Mar 6, 2006 | 05:05 PM
Yes Autometer posted it in my orginal thread.
I am thinking putting important guages in where my heater controls are and buying a few autometer mounts for the roll cage for my oil pressure and boost. But I think they may get in my line of site.
Old Mar 6, 2006 | 05:38 PM
Blown90hatcH's Avatar
Have you already made the pillar bars? If not, you can make it work. I made mine with plenty of clearance and run my gauges on the pillar with the small shift light.
Old Mar 6, 2006 | 05:42 PM
Default Re: Full cage and gauges???? (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Have you already made the pillar bars? If not, you can make it work. I made mine with plenty of clearance and run my gauges on the pillar with the small shift light.</TD></TR></TABLE>
do you mean have I made the pillar bars for the cage already? If so yes the cage is already installed in the car and fits pretty tight to the pillars.
Old Mar 6, 2006 | 05:50 PM
Got ya. Yeah, when I made mine, I put the pillar pod in to make sure it was tight, but cleared. Post up some pics.
Old Mar 6, 2006 | 05:59 PM
If you search under my name in the drag forum you will see the pics of the cage.
So far I have only found that autometer makes the mount for the roll cage
Old Mar 6, 2006 | 06:08 PM
DaveF's Avatar
Old Mar 6, 2006 | 06:22 PM
Default Re: Full cage and gauges???? (Dturbocivic)
I know what yours looks like dave. To bad I still have a stock dash.
Old Mar 6, 2006 | 06:39 PM
DaveF's Avatar
when did you see it
Old Mar 7, 2006 | 06:23 AM
1FSTHATCH's Avatar
Aem has that option too..Oil pressure is important but thats something i dont even watch on the track, just before i go out...only gauge i have in my car is a wideband and its in a pod on the pillar..
Old Mar 7, 2006 | 08:43 AM
boostedcivicsir's Avatar
Mr. Badwrench
since i had to loose my pillar pod, i will just use 2 cups clamped to the a pillar bar.
Old Mar 7, 2006 | 09:22 AM
B18C4-T's Avatar
I put my tach where the factory radio was and my guages in the air vent locations. I'll see if I can come up with some pics for you. My car is sitting in a friends backyard because I moved to Hawaii. Larry
Here is one that I found:
italstallion
24
Jan 8, 2007 08:49 PM
Speed94
Dec 13, 2006 01:27 PM
eghatchomar
Oct 22, 2004 05:52 AM
C M S
May 24, 2004 07:33 PM
DB8
Apr 1, 2003 10:17 PM
