anybody have anything good to say about.
suspension techniques rear sways for the eg? do i really need a beaks kit. the guy at the shop that i am ordering it from says that he has never seen the whole rear subframe tearing occur when you use this bar.
Any bar that is in the smaller 17-19mm range should work fine without worry of sub-frame damage.
If you step up to 20-22mm then the two best choices are the adjustable Comptech and ST Comp kits with the integrated lower rear tie bar. Any other bar in this range will have a high probabilty of lower sub-frame damage without additional support from either Beaks, King or custom welding reinforcements, but even then there is no guarantee.
I have the Comptech personally and love it...blows away any other bar I've driven on hands down.
[Modified by goldnboy6, 12:56 AM 3/31/2002]
i have the progress rear sway bar and its 22mm i havent experienced any problems yet and i got my fingers crosses i had it on my 2000 civic si for about 8 months and it did nothing in the means of messing up the subframe but it made a hel of difference in turning
thanks
chris
thanks
chris
2000GSR
May 5, 2002 03:04 PM
