ZC motor Questions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi »</TD></TR><TR><TD CLASS="quote">Is the ZC "dohc" motor vtech?.........
And can i still run a 91 SI sohc ecu on it?</TD></TR></TABLE>
no its not vtec...the only vtec zc out their is the 1.6 del so vtec zc swap...
Yea thats wat im lookin at....the del sol ZC.....they said it was v tech, but theres no ECU for it.....so can i still run the 91 obd0 SI? or ....am im screwd?
If its a dohc zc it will not be vtec.
If it is a sohc it could be or could not be.
One is like a z6 the other is like the d16a6.
You could use your ecu on any of them and run a vtec controller I reccomend not doing that. If it is a vtec its a great time to wire up to OBD1 also.
mateencrx91
Nov 11, 2003 07:29 PM
