swap info
You can use the d series compressor and lines if you get the correct bracket. You need either a del sol ac bracket for the b16 or you can use one from a 97 CRV. The CRV bracket runs about $70-80 from honda and will directly bolt to the b16 and your d series compressor will directly bolt to the bracket. The CRV bracket is a good bit cheaper so i would recommend getting it instead of the sel sol. As far as the power steering goes, I have no clue.
B16Civic93
Mar 28, 2009 06:25 PM
slowpokesi
17
Jul 20, 2002 08:31 AM
