Hf Brake question??
Old Mar 6, 2006 | 12:40 PM
hooddub's Avatar
Default Hf Brake question??
my buddy and i are swapping over the 91 ls brakes to his hf crx. problem is the hubs are smaller. what would be the easiest route to get the ls hubs to work? and i did use the SEARCH its just hard to find a straight answer.
thanks!!
Old Mar 6, 2006 | 03:20 PM
EL Vap133's Avatar
Default Re: Hf Brake question?? (hooddub)
What parts do you have?
Old Mar 6, 2006 | 05:55 PM
JohnnieChimpo's Avatar
I already did this swap.
If you are using HF axles you will need to swap them out to any other EF axle except 4 speed axles.
Wait till you're done, you'll be able to feel the weight of the brakes when you hit the gas.
I used axles from a 4 door Civic. It may have been automatic too.
Old Mar 7, 2006 | 01:14 AM
hooddub's Avatar
so which axles will work on the ls hubs ? crx si? ex civic eg?
Old Mar 7, 2006 | 05:45 AM
AudioXtremes's Avatar
Default Re: (hooddub)
88-91 CRX DX and SI, or 89-91 Civic SI axels will work.
Old Mar 7, 2006 | 07:51 PM
hooddub's Avatar
thanks man
firejackal
Jul 12, 2012 10:11 AM
tyvtec23
Mar 6, 2012 08:48 AM
onemore
Jan 9, 2008 03:51 PM
1CiViC1
May 29, 2003 02:29 PM
Nossy
10
May 4, 2002 10:00 AM
