1990 standard hatch+si trans question
Old Mar 6, 2006 | 08:36 AM
highrev1987's Avatar
Default 1990 standard hatch+si trans question
i have a 1990 hatch with a 4 spd trans do i have to change out the axles and hubs to use a 1990 crx si transmission. please help but only if you ve done it before
btw 88-89 civs are different.
Old Mar 6, 2006 | 08:45 AM
turboLSef's Avatar
Default Re: 1990 standard hatch+si trans question (highrev1987)
the tranny will bolt up and you can use your same axles
Old Mar 6, 2006 | 08:46 AM
Ak_ef9's Avatar
Default Re: 1990 standard hatch+si trans question (turboLSef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboLSef &raquo;</TD></TR><TR><TD CLASS="quote">
the tranny will bolt up and you can use your same axles </TD></TR></TABLE>
Yup
Old Mar 6, 2006 | 10:04 AM
EJ1 wilcox's Avatar
Default Re: 1990 standard hatch+si trans question (Ak_ef9)
I have an Si tranny in my 90 standard hatch.
Everything bolts right up.
The only thing I don't like about the Si tranny is the 5th gear. I wish it was a little taller, I'm at like 3500 RPMs when cruising at 65 on the freeway.
Old Mar 7, 2006 | 08:00 AM
Default Re: 1990 standard hatch+si trans question (EJ1 wilcox)
Can i use the Crx si one? i dunno if the hubs and axles are the same for the Crx.
Old Mar 7, 2006 | 08:03 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 &raquo;</TD></TR><TR><TD CLASS="quote">Can i use the Crx si one? i dunno if the hubs and axles are the same for the Crx.</TD></TR></TABLE>
Yes, that's what I'm using, a CRX Si tranny in my STD hatch. It's the same tranny as the hatch Si and I think the manual EX sedan as well.
Old Mar 14, 2006 | 01:28 AM
pork.'s Avatar
you can swap the tranny , not the axles . if you swap axles you will have to swap hubs also ..
Old Mar 14, 2006 | 04:52 AM
Default Re: 1990 standard hatch+si trans question (pork.)
trans is already done
Old Mar 14, 2006 | 05:05 AM
neomnj's Avatar
wow this looks like a good idea. im thinking about doing a mini me swap or a b16. if i do a si tranny swap that trans wont hold a b16. will it??
Old Mar 14, 2006 | 05:11 AM
si0385.'s Avatar
Default Re: (neomnj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neomnj &raquo;</TD></TR><TR><TD CLASS="quote">wow this looks like a good idea. im thinking about doing a mini me swap or a b16. if i do a si tranny swap that trans wont hold a b16. will it??</TD></TR></TABLE>
nope needa b series tranny
Old Mar 14, 2006 | 06:21 AM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">I have an Si tranny in my 90 standard hatch.
The only thing I don't like about the Si tranny is the 5th gear. I wish it was a little taller, I'm at like 3500 RPMs when cruising at 65 on the freeway. </TD></TR></TABLE>it should be more like 3300 at 70mph. your describing the rpms of a ZC tranny. unless you dont have stock size tires
Old Mar 14, 2006 | 06:44 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pork. &raquo;</TD></TR><TR><TD CLASS="quote">you can swap the tranny , not the axles . if you swap axles you will have to swap hubs also .. </TD></TR></TABLE>
Wrong. It's a direct replacement. Axles and all. You don't have to swap the hubs or anything like that.
Old Mar 14, 2006 | 09:01 AM
FernEF's Avatar
I thought with a STD hatch in order to throw a motor in, u need to change the front spindles in order for the axles to fit cuz the STD hubs are a differnet axle size now thats only with STD, dx u dont have to change. when i first got my std hatch i replaced my axles and i had the 4speed tranny at the time and i ordered axles for a si tranny thinking they were the same and they didnt fit.. so i had to return them and then specify and tell them that it was for a 4speed not 5.
Old Mar 14, 2006 | 09:06 AM
EJ1 wilcox's Avatar
Default Re: 1990 standard hatch+si trans question (FernEF)
I used the stock axles from the 4 speed tranny and they slid right into the Si tranny.
They have been working fine for me.
Old Mar 14, 2006 | 09:07 AM
well what year was your std? was it 89-91 if so then the std axles would've worked fine if not then you had to swap them. i have the crx si l3 trans in my 90 hatch and i am running a crx si clutch by exedy and no problems.
Old Mar 14, 2006 | 09:11 AM
FernEF's Avatar
its a 90'
Old Mar 14, 2006 | 09:13 AM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FernEF &raquo;</TD></TR><TR><TD CLASS="quote">I thought with a STD hatch in order to throw a motor in, u need to change the front spindles in order for the axles to fit cuz the STD hubs are a differnet axle size now thats only with STD, dx u dont have to change. when i first got my std hatch i replaced my axles and i had the 4speed tranny at the time and i ordered axles for a si tranny thinking they were the same and they didnt fit.. so i had to return them and then specify and tell them that it was for a 4speed not 5. </TD></TR></TABLE>only if you are trying to use SI or DX axles with stock hubs. the STD or HF axles will work just fine with the stock hubs and SI tranny
Old Mar 14, 2006 | 09:15 AM
FernEF's Avatar
so what u r saying is that with the stock 4speed axles they fit wit no prob wit a 5speed into the hub, but wit a bseries motor in ur hatch the axles wont fit ur STD hub correct??
Old Mar 14, 2006 | 10:49 AM
boostinaintez's Avatar
b16 need b series tranny
Old Mar 14, 2006 | 10:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FernEF &raquo;</TD></TR><TR><TD CLASS="quote">so what u r saying is that with the stock 4speed axles they fit wit no prob wit a 5speed into the hub, but wit a bseries motor in ur hatch the axles wont fit ur STD hub correct??</TD></TR></TABLE>
research
Old Mar 14, 2006 | 10:59 AM
d16dcoe45's Avatar
Default Re: 1990 standard hatch+si trans question (ryan89crx)
I am 99% sure the EX has a 4.08 FD while the si has 4.25 and the DX has 3.888. The HF is alot taller than any of them.......
Old Mar 14, 2006 | 11:03 AM
crxnj's Avatar
Default Re: 1990 standard hatch+si trans question (d16dcoe45)
listen,,All the axles have the same inner joint..So you can use the STD/HF axles in the other trannys.. The difference with the STD/hf axles is on the outer joint of the axles ,,being smaller then the rest..
Old Mar 14, 2006 | 11:23 AM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">The only thing I don't like about the Si tranny is the 5th gear. I wish it was a little taller, I'm at like 3500 RPMs when cruising at 65 on the freeway. </TD></TR></TABLE>thats nothing...my S1 tranny sits at about 5k doing 65. talk about annoying.
Old Mar 14, 2006 | 11:31 AM
31flavorscivic's Avatar
Default Re: 1990 standard hatch+si trans question (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">thats nothing...my S1 tranny sits at about 5k doing 65. talk about annoying. </TD></TR></TABLE>
With my ZC transmission im at about 4500 going 90 MPH. When I had my race muffler on it was deafening driving home 4 hours from the track
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">listen,,All the axles have the same inner joint..So you can use the STD/HF axles in the other trannys.. The difference with the STD/hf axles is on the outer joint of the axles ,,being smaller then the rest..</TD></TR></TABLE>
That ended up being a huge roadblock in my swap, when halfway through I found out someone had put standard hubs on my SI a long time ago. I was quite mad.
Old Mar 14, 2006 | 11:34 AM
crxnj's Avatar
Default Re: 1990 standard hatch+si trans question (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">
That ended up being a huge roadblock in my swap, when halfway through I found out someone had put standard hubs on my SI a long time ago. I was quite mad.</TD></TR></TABLE>
What kind of bad luck is that?
jayhelladum
Sep 25, 2008 09:27 AM
LurkerS8
17
Jun 25, 2005 07:46 AM
Gant
Jun 12, 2004 09:35 PM
sabertooth
Apr 22, 2003 04:18 AM
Nossy
Apr 10, 2002 10:33 PM
