DIY: Type R Valve Cover....Write up...56K BEWARE...
Old Mar 5, 2006 | 11:41 PM
igone916's Avatar
Default DIY: Type R Valve Cover....Write up...56K BEWARE...
I got bored of my black valve cover so I decided to painted it. It's not the best but it looks better now. It cost me less than $50...Here's my write up, hopefully it's helpful to all of you...
Things I used...
Aircraft paint removal
Paint Brush (Brush off original coating of the valve cover)
VHT Red Wrinkle Plus Paint
Tape
Sand paper
Gloves
Here's a look of my original valve cover. First, I took off all the bolts to remove the valve cover. After the valve cover was removed, I took off all of the seals.
Then pour the Aircraft Remover over the valve cover and allowed the solution do its thing. Let it sit for about 10-15 mins and brush off all of the original coating. You might have to use some more Aircraft Remover to remove the remaining coating.
I then watered down the valve cover and dried it for prepping. I only covered the oil hole and the spark plug holes.
I then painted my valve cover 3 coats with 2-3 mins in between. It took about 4-5 hours to dry and because it was cold outside. After it was dried, I sanded down the letters for a smooth finish. I replaced all of my valve cover seals and put the valve cover back on. Be careful with tightening the bolts because they can break easily. Here are pics of my finished valve cover. Comments are welcome...This is my first write up, I apologize if its not perfect...Thanks...
Modified by igone916 at 12:56 AM 3/6/2006
Old Mar 5, 2006 | 11:43 PM
playalistic2's Avatar
Default Re: DIY: Type R Valve Cover....Write up...56K BEWARE... (igone916)
nice now clean the bay
dreww..'s Avatar
Nice work
Old Mar 5, 2006 | 11:45 PM
No_Fear's Avatar
looks very good
Old Mar 5, 2006 | 11:49 PM
M2S~Juan's Avatar
wow! that is freaking awesome... I'm gonna do this too!
Old Mar 5, 2006 | 11:50 PM
JDM INSPIRED's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreww.. &raquo;</TD></TR><TR><TD CLASS="quote">Nice work </TD></TR></TABLE>
Old Mar 5, 2006 | 11:57 PM
igone916's Avatar
Default Re: DIY: Type R Valve Cover....Write up...56K BEWARE... (playalistic2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playalistic2 &raquo;</TD></TR><TR><TD CLASS="quote">nice now clean the bay</TD></TR></TABLE>
Hahhahaah...thanks, thats my next step...
Old Mar 6, 2006 | 12:07 AM
JerkzEm1's Avatar
Default Re: (dreww..)
Old Mar 6, 2006 | 02:42 AM
JonnySBeee...'s Avatar
wut grit sandpaper did u use for the sanding? thanks
IT'S ME DAVID's Avatar
NooB
thanks for the 100th write up on this but please keep the pics hosted for future help.also you can use chapstick or vasoline on the letters then paint the valve cover when dried the paint on the letter just wipe off no sanding or dremel tool required.
Old Mar 6, 2006 | 02:46 AM
Default Re: DIY: Type R Valve Cover....Write up...56K BEWARE... (EJ8 DAVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 DAVID &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the 100th write up on this but please keep the pics hosted for future help.also you can use chapstick or vasoline on the letters then paint the valve cover when dried the paint on the letter just wipe off no sanding or dremel tool required. </TD></TR></TABLE>
wow thats a good idea, would you suggest doing this for the headlight housing?
Old Apr 6, 2006 | 11:29 PM
HBADGE's Avatar
Default Re: DIY: Type R Valve Cover....Write up...56K BEWARE... (mmhmm)
good DIY
Old Jan 7, 2007 | 03:13 PM
skinnyboy's Avatar
Default Re: DIY: Type R Valve Cover....Write up...56K BEWARE... (HBADGE)
heres a tip for using the VHT stuff
I found that it takes its sorry *** time to get the desired wrinkle effect, so i used a heatgun on it, ever so gently though, heat the area until it wrinkles and then move on to the next spot, always move the gun and don't stay in one spot for too long.
Voila!
Modified by skinnyboy at 10:53 AM 1/8/2007
Old Jan 7, 2007 | 03:15 PM
845_dapek's Avatar
Default Re: DIY: Type R Valve Cover....Write up...56K BEWARE... (skinnyboy)
Old Jan 7, 2007 | 03:25 PM
Conechasing's Avatar
Default Re: DIY: Type R Valve Cover....Write up...56K BEWARE... (gsrteggyflyin)
Nice work.
Old Jan 7, 2007 | 03:29 PM
CXtypeR's Avatar
the next time i paint my valve cover
ill do 3-4 coats. after each light coat, blowdry the bitch and youll see it wrinkle on the spot.
now, instead of waiting days for it to completely dry, ill just wait a day and install it and let vtec finish baking itl
Old Jan 7, 2007 | 03:48 PM
skinnyboy's Avatar
Default Re: (CXtypeR)
my method was to paint one horizontal light coat, then wait 1 hour, then paint 1 vertical coat, wait an hour, then one thickish horizontal coat, let dry for 30 minutes, then heatgun that coat. Its all in the prep as well, make sure its squeaky clean and for vibrant red, use an etch primer. I also used Vaseline on the lettering and sprayed over this, the once the paint is dry, used a razer blade and skimmed off the paint easily off the lettering. Waiting a day, then steel wool'ed the letters for a nice smooth finish.
Old Jan 7, 2007 | 04:14 PM
RIPracing's Avatar
Default Re: DIY: Type R Valve Cover....Write up...56K BEWARE... (Conechasing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Conechasing &raquo;</TD></TR><TR><TD CLASS="quote">Nice work. </TD></TR></TABLE>
Old Jan 7, 2007 | 04:23 PM
K20EF8Dx's Avatar
Default Re: DIY: Type R Valve Cover....Write up...56K BEWARE... (RIPracing)
Never herd of VHT paint ima have to look for some... Nice write up...
Old Jan 7, 2007 | 04:40 PM
cd5_2NR's Avatar
Old Jan 7, 2007 | 04:52 PM
B16B_coupe's Avatar
HRD PKR
Default Re: Re: (JDM INSPIRED)
nice work dude! looks really good
Old Jan 7, 2007 | 05:19 PM
waddy41's Avatar
it's a lil bright
Old Jan 8, 2007 | 02:08 AM
jonshonda's Avatar
Community Builder
looks good
Old Jan 8, 2007 | 02:48 AM
Crasian's Avatar
im still lookin for a place to buy that paint here in canada
Old Jan 8, 2007 | 04:39 AM
skinnyboy's Avatar
Default Re: (Crasian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crasian &raquo;</TD></TR><TR><TD CLASS="quote">im still lookin for a place to buy that paint here in canada </TD></TR></TABLE>
30 seconds in Google gives me this Canadian Retailer
http://www.hivolume.com/en/contact.php
And their line of VHT Paints
http://www.hivolume.com/en/list.php?ID=84
