b18c swapped CRX HF
Please excuse my ignorance if I am posting a talked about subject, but i tried searching and came up no results on a GSR swap into an HF. I've read somewhere that the HF requires more modifcation than lets say a Si does. I'm just curious to what that might be besides the parts that come with the engine on Hmotorsonline.com such as Axles with half shaft, shift linkage and my optional LSD tranny etc. Please let me know.. Thank You
HF has different hubs than the SI/DX/LX/EX models, you would need to score some from a junkyard or something. you also need 90-93 integra rear and left engine mount brackets if your using hasport or similar mounts. you would need mounts, and a hydro to cable tranny conversion. the stock gsr shift linkage wont work. you will need a part from say hasport. i'm not sure but you may need different axles than the stock gsr ones also, not sure. you will also need to consider wiring vtec and posibly converting to obd 1. i'm sure that i missed alot, so find a tutorial ask alot of questions (to hmotorsonline.com or your other part sources). and good luck.
Yeah it would be better to convert to obd1 and run the gsr p72 ecu..Especially if you plan on using the stock gsr manifold with the butterflies working..As far as axles the 94 integra gsr axles will work fine with that swap since it should have 94+ integra indermedate shaft ..Like jacoop86 said youll need mounts and a custom linkage,,
Also with the Hf's there is something about the reverse lights ..When swapping out the stock ecu,,They're wired to the hf ecu or something..I forget
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmrCRX »</TD></TR><TR><TD CLASS="quote">Please excuse my ignorance if I am posting a talked about subject, but i tried searching and came up no results on a GSR swap into an HF. I've read somewhere that the HF requires more modifcation than lets say a Si does. I'm just curious to what that might be besides the parts that come with the engine on Hmotorsonline.com such as Axles with half shaft, shift linkage and my optional LSD tranny etc. Please let me know.. Thank You
You are going to want to convert to obd1, ryan at rywire (www.rywire.com) will take care of you, give him a call
</TD></TR></TABLE>You are going to want to convert to obd1, ryan at rywire (www.rywire.com) will take care of you, give him a call
civicdust
May 2, 2005 09:11 PM
dipillo
May 1, 2005 01:11 PM
