Is this a possible slave cylinder problem???
Old Mar 5, 2006 | 08:09 PM
alfee's Avatar
Default Is this a possible slave cylinder problem???
need some advice.. While putting my motor back together with my new clutch, I took the slave cylinder off and somehow the inside boot in the slave tore open exposing the spring inside along with a pointy top peice. That spring popped out but I was able to locate it with the other peice and put them back in snuggly with the clutch fork that connected to it.
Now, when bleeding the clutch it feels somewhat soft, not what I'm used to at all. The clutch does pop out though. When bleeding and holding the clutch in and releasing it, the clutch does not pop back out though however. Is this a sign that I need a new slave cylinder? Btw, my cmc is fine no leaks and no leaks in the firewall inside the car either. I've bled the clutch a 3rd time now and its still not hard at all, just snug enough to where i can step on it to start the car and it'll pop back out.
Old Mar 19, 2006 | 01:02 PM
chrisgottigsr's Avatar
Default Re: Is this a possible slave cylinder problem??? (alfee)
CHECK YOUR PM'S ALFEE
Old Mar 27, 2006 | 06:21 PM
check your pm's and email alfee
pointblank2305
Dec 26, 2012 05:03 PM
ohsnapzafingcu
May 16, 2011 04:30 PM
Ek9_Cuhzz
Honda S2000
Apr 23, 2011 07:30 PM
94civicgsr
Dec 25, 2007 06:29 PM
majinx4
Jun 15, 2006 11:30 AM
