azenis vs. goodyears
Old Mar 5, 2006 | 07:39 PM
pulpdeem's Avatar
Default azenis vs. goodyears
which is the better summer tire? azenis or the grippy goodyears gsd3? something like that.
Old Mar 5, 2006 | 08:31 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: azenis vs. goodyears (pulpdeem)
You're comparing the Falken Azenis RT-615 with the Goodyear F1 GS-D3. They are both excellent tires, but in different ways.
The Falken provides greater grip on dry pavement (and is only so-so on wet pavement, although better than its RT-215 predecessor). The Goodyear provides greater grip on wet pavement (and it's still very very good on dry pavement).
The Falken costs about two thirds as much. The Goodyear lasts about three times as many miles. So on a cost per mile basis, the Goodyear is significantly less expensive.
The Falken is available in 205/50-15 and 215/45-16, both of which are good for Integras and '96-00 Civics. The Goodyear is available in 195/50-15 for pre-'96 Civics, and 205/45-16 for Integras.
If both tires are available in a size for the wheels and tires on your car, then I would suggest the Falken if you're using it mostly for autocross or track events, where the dry performance is most important, and the Goodyear if you're using it mostly for daily driving, where the treadlife and wet performance are also important.
Modified by nsxtasy at 7:57 AM 3/6/2006
Old Mar 6, 2006 | 04:24 AM
pulpdeem's Avatar
Default Re: azenis vs. goodyears (nsxtasy)
good info
Old Mar 6, 2006 | 09:26 AM
b00stedeg's Avatar
I use the hankook ventus rs2 which is much like the old azenis, very grippy
Old Mar 6, 2006 | 10:40 AM
central_driver's Avatar
Default Re: (b00stedeg)
im using that tire now and on wet surfaces they spin all the way tell i shift into 3rd with a stock motor
Old Mar 6, 2006 | 12:34 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (central_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00stedeg &raquo;</TD></TR><TR><TD CLASS="quote">I use the hankook ventus rs2 which is much like the old azenis, very grippy</TD></TR></TABLE>
The Hankooks aren't as fast on the autocross course as either Azenis, according to Grassroots Motorsports, and Car and Driver rated the Goodyears better than the Hankooks for dry performance as well as wet performance.
Old Mar 24, 2006 | 10:18 AM
b16adx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by central_driver &raquo;</TD></TR><TR><TD CLASS="quote">im using that tire now and on wet surfaces they spin all the way tell i shift into 3rd with a stock motor</TD></TR></TABLE>
hmm i didnt realize they were suppose to grip like a slick on wet surface
Old Mar 24, 2006 | 10:42 AM
b00stedeg's Avatar
I havent really had a chance to test them out in the rain so i dont know, if im driving and it happens to start raining im not really pushing the car so much, ive had them for a while now and ive liked them
nathanie1
Feb 10, 2005 03:20 PM
patmcd
Apr 20, 2004 08:44 PM
typeR 507
Apr 18, 2003 01:38 PM
NightHawkC5
Feb 22, 2003 01:59 PM
01geeser
May 14, 2002 03:39 PM
