Coilovers pisses me off
Old Mar 5, 2006 | 05:13 PM
$amGD3's Avatar
Swaggylicious
Default Coilovers pisses me off
grrr,i must've jacked up the car 20 times since thursday because i'm trying to even out the drop height.I measure from the ground to the middle(highest) point on the fender,front driver's and passenger side have a 1cm difference,back driver's and passenger side have a .5cm difference
..i give up,lol
here's a pic when it was slammed as hell and it still has a loong way to go down in the front,i've raised the front a bit cause i rubbed when i turned like this
Old Mar 5, 2006 | 05:18 PM
MITeggy17's Avatar
Default Re: Coilovers pisses me off (sam21)
Get wheels
Old Mar 5, 2006 | 05:19 PM
$amGD3's Avatar
Swaggylicious
Default Re: Coilovers pisses me off (MITeggy17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITeggy17 &raquo;</TD></TR><TR><TD CLASS="quote">Get wheels </TD></TR></TABLE>i'm gettin there
Old Mar 5, 2006 | 05:24 PM
$amGD3's Avatar
Swaggylicious
Default Re: Coilovers pisses me off (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">i just slammed my car today, 1 finger gap all around EXCEPT the front passenger side, which is a tad higher, gotta lower that side a little...but i hate doing it</TD></TR></TABLE>you'll hate it even more when it's like the 20th time you've done it
dreww..'s Avatar
or a lower profile tire
Old Mar 5, 2006 | 05:25 PM
honda_kid42's Avatar
been there before...looks pretty good slammed tho...
Mark D. Surface's Avatar
Looks good!
I pre-adjusted mine by measuring them while they were off the car to a height that might be appoximately where i wanted it to sit, but I guees that would be too late for you!
Old Mar 5, 2006 | 05:27 PM
$amGD3's Avatar
Swaggylicious
Default Re: Coilovers pisses me off (Mark D. Surface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mark D. Surface &raquo;</TD></TR><TR><TD CLASS="quote">Looks good!
I pre-adjusted mine by measuring them while they were off the car to a height that might be appoximately where i wanted it to sit, but I guees that would be too late for you!</TD></TR></TABLE>thanks
i actually did that counted how many threads and all,but somewhere between sliding the sleeve in and mounting the strut assembly on the car and taking it off jack stands,the results i got werent exactly awesome
Old Mar 5, 2006 | 05:29 PM
beedoublejay's Avatar
When measuring DO NOT measure from the ground to the fender. The ground is inconsistant and so are tire pressures making each side different. Measure from the highest point of the curve in the fender/middle to the center of the wheel. This will give you an accurate measurment.
Old Mar 5, 2006 | 05:32 PM
$amGD3's Avatar
Swaggylicious
Default Re: Coilovers pisses me off (beedoublejay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beedoublejay &raquo;</TD></TR><TR><TD CLASS="quote">When measuring DO NOT measure from the ground to the fender. The ground is inconsistant and so are tire pressures making each side different. Measure from the highest point of the curve in the fender/middle to the center of the wheel. This will give you an accurate measurment. </TD></TR></TABLE>hmm never thought about that,but if the ground isnt consistant wouldnt be the same for the wheels,i mean the distance of the center of the wheel to the fender will vary too right?
Old Mar 5, 2006 | 05:33 PM
usdmEHboy's Avatar
good advice
Old Mar 5, 2006 | 05:38 PM
TeH PLAYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreww.. &raquo;</TD></TR><TR><TD CLASS="quote">
or a lower profile tire </TD></TR></TABLE>
Old Mar 5, 2006 | 05:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam21 &raquo;</TD></TR><TR><TD CLASS="quote">hmm never thought about that,but if the ground isnt consistant wouldnt be the same for the wheels,i mean the distance of the center of the wheel to the fender will vary too right?</TD></TR></TABLE>
It seems that way but not true, based on the geometry of the suspension the distance of the center of the wheel to the fender will be consistant. When I worked at Ground-Control this is how we would measure for corner weighting cars.
Old Mar 5, 2006 | 05:47 PM
5STAR3's Avatar
Default Re: Coilovers pisses me off (THE PLAYER)
what kind of coilovers?
Old Mar 5, 2006 | 05:52 PM
$amGD3's Avatar
Swaggylicious
It seems that way but not true, based on the geometry of the suspension the distance of the center of the wheel to the fender will be consistant. When I worked at Ground-Control this is how we would measure for corner weighting cars. </TD></TR></TABLE>ahh,freakin math and those damn axis,lol
Old Mar 5, 2006 | 05:56 PM
$amGD3's Avatar
Swaggylicious
Default Re: Coilovers pisses me off (5STAR3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5STAR3 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of coilovers?</TD></TR></TABLE>Omni Power slip
Old Mar 5, 2006 | 05:57 PM
dut's Avatar
dut
Just lower all coilovers all the way down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam21 &raquo;</TD></TR><TR><TD CLASS="quote">Omni Power slip </TD></TR></TABLE>
oooohhhhhhhhhh....
Old Mar 5, 2006 | 06:03 PM
slammed_93_hatch's Avatar
BJ is right. Except keep in mind that if you have ever had a little fender bender and didn't get things exactly right, they may be different.
acctually that wont work either
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam21 &raquo;</TD></TR><TR><TD CLASS="quote">thanks
i actually did that counted how many threads and all,but somewhere between sliding the sleeve in and mounting the strut assembly on the car and taking it off jack stands,the results i got werent exactly awesome </TD></TR></TABLE>
No nothing moved most likely. the weight at each corner of the car is different, so the amount that the spring will be compressed is also going to be different. Which will give you different heights at each corner.
Honestly though, you guys are freaking out about 1 or even .5 centimeters. NO ONE will be able to tell, and most likely you weren't on perfectly flat surface, so it wasn't really level to begin with.
Old Mar 5, 2006 | 06:04 PM
Calliefornia's Avatar
Default Re: (dut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dut &raquo;</TD></TR><TR><TD CLASS="quote">Just lower all coilovers all the way down. </TD></TR></TABLE>
Old Mar 5, 2006 | 06:11 PM
H.A.R.T B18C1EG6's Avatar
Default Re: (dut)
Old Mar 5, 2006 | 06:17 PM
$amGD3's Avatar
Swaggylicious
Default Re: (dut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dut &raquo;</TD></TR><TR><TD CLASS="quote">Just lower all coilovers all the way down. </TD></TR></TABLE>lol,i dont know how people can drive lower than this,i can barely get out of my driveway,i couldnt even get up my friends driveway the other day!
Old Mar 5, 2006 | 06:18 PM
Default Re: Coilovers pisses me off (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">...the weight at each corner of the car is different, so the amount that the spring will be compressed is also going to be different. Which will give you different heights at each corner.
Also a big factor, I forgot to mention that.
Old Mar 5, 2006 | 06:20 PM
SiB16A's Avatar
Default Re: (H.A.R.T B18C1EG6)
wheels and youll be set
Old Mar 5, 2006 | 06:35 PM
918-Hatch's Avatar
Colorado <3
count threads
