got a problem 01 accord
Old Mar 5, 2006 | 12:56 PM
firbster's Avatar
Default got a problem 01 accord
well first off im new here ..just bought a 2001 accord coupe v6 and i have had to do some body repairs ..had to replace the door ...i disconnected the battery while doing all the work now i reconnect the battery and the car wont turn over..nothing at all and the drive light on the dash is flashing...i dont have the owners manual so i have no idea ..i also have a 90 exr which i love so thought id stick with accords..again if you could point me in the right direction great..
Old Mar 5, 2006 | 01:07 PM
YeuEmMaiMai's Avatar
Default Re: got a problem 01 accord (firbster)
if your [D] light is blinking, you have a transmission code. YOu need to pull that code and tell us what it is before you can continue.
Go and check all of the connections on the transmission and make sure that one is not disconnected.
Old Mar 5, 2006 | 04:34 PM
firbster's Avatar
Default Re: got a problem 01 accord (YeuEmMaiMai)
well found the problem...when changing the door i had to get into the fuse panel to unplug the door harness and being a dumb *** i unpluged the tranny one aswell...is fixed thanks for the quick response..
emagill
Jul 19, 2011 07:40 AM
rideimport
Oct 26, 2008 05:48 PM
teqp
Sep 24, 2008 07:07 AM
