swapping cranks from block 2 block, can i use oem bearings?
i have 2 ls blocks. one has good internals but the keyway part of the crannk is all messed up so i cant use the crank. the other block just has no internals. so can i use the stock replacement bearings when i switch the crank and rods to the other block?
Topdawgg
Jan 5, 2006 06:32 PM
SQ is the SQUAD
Oct 27, 2005 04:59 PM
