Making a left hand driver into a right hand driver
Ok I'm building a 91 Si, I've done an H22 swap.I'm wanting to convert my left hand driver into a right hand driver,to get it as close to J-Spec as possible.I was swondering if there is anyway and where i can get the stuff to do the conversions.
Do a search this has been discussed many times. Easiest way is to do a firewall swap (IMO it's not really worth it).
Edit: Check this: https://honda-tech.com/zerothread?id=1262826
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCRX6919832002 »</TD></TR><TR><TD CLASS="quote">Ok I'm building a 91 Si, I've done an H22 swap.I'm wanting to convert my left hand driver into a right hand driver,to get it as close to J-Spec as possible.I was swondering if there is anyway and where i can get the stuff to do the conversions.</TD></TR></TABLE>
than just order an sir front clip for about 4k and get rid of that h22 if you wanna get as close to j-spec as possible
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sci_v_icI »</TD></TR><TR><TD CLASS="quote">dont do a firewall swap way too much unnecessary work. just get a jdm front clip
what do you suggest? is there an easier method?
</TD></TR></TABLE>what do you suggest? is there an easier method?
