Looking for stock ride height measurements
Old Mar 30, 2002 | 03:49 PM
StageOne's Avatar
Default Looking for stock ride height measurements
I installed a set of adjustable coilovers last weekend and like a dumbass I forgot to get the stock measurements. Can anyone measure from the ground to the middle of the wheel arch on a stock suspended R for all 4 corners. I am trying to get close to stock or at least find out how much lower I am.
Many thanks and If you are ever in the Ohio area
Old Mar 30, 2002 | 04:02 PM
TypeR 599's Avatar
Default Re: Looking for stock ride height measurements (StageOne)
From the bottom of the center cap to the edge of the fender at the top of the wheel well: 14 7/8" front, 15 1/8" rear.
the tire pressure can change the height...the center cap is more accurate.
Old Mar 30, 2002 | 04:20 PM
AllMotorITR's Avatar
New User
Default Re: Looking for stock ride height measurements (TypeR 599)
OT: Post 1800!
Old Mar 30, 2002 | 04:44 PM
Todd00's Avatar
I said I don't want a title!
I had those measurements at one time, but I've since lost the piece of paper that I had them on. The figures posted sounds about right though.
Figure out how to adjust the Zeals yet? The guy who installed those really knows his ****
Old Mar 30, 2002 | 08:24 PM
StageOne's Avatar
Default Re: Looking for stock ride height measurements (Todd00)
The install was top notch, but then I had to go and screw things up by changing the front springs!!! Now I probably really messed things up.
TypeR 599 - Thanks a bunch. owe you a or
[Modified by StageOne, 12:25 AM 3/31/2002]
Old Mar 30, 2002 | 08:27 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Looking for stock ride height measurements (1 FAST R)
OT: Post 1800!
Your post count should now drop to 0.
Old Mar 31, 2002 | 11:48 AM
albert butterbikini's Avatar
New User
Default Re: Looking for stock ride height measurements (B18C-EJ1)
Should be about 24.5" from ground to bottom edge of fender.
bopbop93030
Suspension & Brakes
Mar 29, 2009 08:57 AM
Siegfried
May 29, 2007 11:21 AM
Quick Silver
Apr 7, 2003 08:04 PM
alfaaay
Mar 19, 2003 03:42 PM
TypeR 599
Dec 21, 2001 04:19 PM
