How long do DC2 LS or GSR Transmissions Last? Might Need a Tranny. Where to Buy?
Old Mar 5, 2006 | 07:05 AM
shortdahri's Avatar
Default How long do DC2 LS or GSR Transmissions Last? Might Need a Tranny. Where to Buy?
I did a LS to GSR swap and the GSR transmission I got with the donor engine has a damaged case so I've decided to replace it.
I can either purchase another tranny or use the LS tranny that was originally in the car but it has 110k miles.
Does anyone know how long the LS transmissions last (mileage wise)?
Does anyone know a reputable place to buy either a GSR or Type-R tranny for a reasonable price?
Thanks.
Old Mar 5, 2006 | 07:19 AM
Lauj87's Avatar
there all honda transmissions..they will all out live you and your children lol...but if you search around you'll find one. look at marketplace and ebay (just be careful on ebay).
Old Mar 5, 2006 | 07:35 AM
b62pteg#2's Avatar
Default Re: How long do DC2 LS or GSR Transmissions Last? Might Need a Tranny. Where to Buy? (shortdahri)
Heads up though if you're not aware. An LS tranny (long gears) on a GSR (VTEC engine for that matter) isn't the best combo.
Just a heads up, it's one of the rare but pretty much agreed upon things on here.
But if you're in a bind and need something, then go ahead I guess!
-- Kevin
Old Mar 5, 2006 | 07:40 AM
Danziver's Avatar
Default Re: How long do DC2 LS or GSR Transmissions Last? Might Need a Tranny. Where to Buy? (b62pteg#2)
Good luck finding a hydro. Those are becoming scarce.
Old Mar 5, 2006 | 08:15 AM
teggy182's Avatar
depneds how you drive for the lifetime on trannies/ and id try to get the tranny from a junk yard
Old Mar 5, 2006 | 10:38 AM
91 teg's Avatar
i had 200,000 on my stock ls tranny....
Old Mar 5, 2006 | 08:20 PM
shortdahri's Avatar
I'd probably get a clutch and flywheel because I plan on turbocharging before swapping the tranny.
Any preventative measures or maintenance I should do on the LS tranny if I end up putting it on the car?
Old Mar 5, 2006 | 09:16 PM
mRs_PaNdA's Avatar
call up hmotorsonline they will hook you up that's where I got mine.
Old Mar 6, 2006 | 05:03 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<-- 225,000 miles on original tranny, has never had any internal work done on it.
Old Mar 6, 2006 | 05:13 AM
Micha's Avatar
FAILWGN
Default Re: (PatrickGSR94)
What is a reasonable price? You can still go to the dealership and buy them new I believe.
Old Mar 6, 2006 | 06:22 AM
IntegraLova's Avatar
Why dont you just take the gsr case off and put the ls case on the gsr tranny? You said that it was the case on the tranny that was damaged.This way you keep your short gears.
Old Mar 6, 2006 | 07:31 AM
db8gsr_teg's Avatar
just get a hydro b16 tranny
Old Mar 6, 2006 | 10:26 AM
shortdahri's Avatar
Default Re: How long do DC2 LS or GSR Transmissions Last? Might Need a Tranny. Where to Buy? (IntegraLova)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLova &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you just take the gsr case off and put the ls case on the gsr tranny? You said that it was the case on the tranny that was damaged.This way you keep your short gears. </TD></TR></TABLE>
Anyone have a write up on this? How hard is this to do? Any speciality tools needed?
Old Mar 6, 2006 | 10:28 AM
shortdahri's Avatar
Default Re: (Blu99teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">What is a reasonable price? You can still go to the dealership and buy them new I believe. </TD></TR></TABLE>
I don't prefer to buy it new because its pretty expensive. On the other hand, used is sometimes unreliable. I guess i'll know when I see it.
Krucial_Ek9
Apr 11, 2008 09:25 PM
ppg97ek
Sep 4, 2007 01:51 PM
Danziver
Jan 27, 2006 04:17 PM
GoldenONE
Sep 8, 2002 11:08 PM
Integra187
Oct 5, 2001 01:49 PM
