suspension problems help!!!!
Old Mar 4, 2006 | 11:47 PM
sohctodohc's Avatar
Default suspension problems help!!!!
so awhile back i got a nasty clunk from driver side sounded like a ball joint clunk. replaced lower ball joints on both sides. that didnt fix it. got omni power upper control arms with the new balljoints. that didnt fix it. axles and cv shafts are both good. replaced inner tie rod. it was bad solved problem for like a hour then clunking came back. could it be outer tie rod? the rack? theres not a whole lot left to replace any help would be fan-*******-tastic
this is on a 94 civic ex
Old Mar 5, 2006 | 12:00 AM
Kevinarich's Avatar
is it only when you turn the wheel? if it when you are turning the wheel, then it might be loose rack mounts, the bushings might be wasted.thats all i can think of.
Old Mar 5, 2006 | 12:01 AM
sohctodohc's Avatar
Default Re: (Kevinarich)
only happens when i hit bumps
Old Mar 5, 2006 | 02:12 PM
sohctodohc's Avatar
Default Re: (sohctodohc)
ttt
Old Mar 5, 2006 | 02:45 PM
92hatchling's Avatar
check the wheel bareing i had a smiler problem and it was a bad baring
Old Mar 5, 2006 | 09:54 PM
Kevinarich's Avatar
make sure everythings tight. pick the car up and wiggle the wheel from top to bottom, if its loose you need a bearing, then try left to right, if its loose you need tie rods or the rack is loose, but if its not either one then check the strut mounts on top and bottom, if its not that then talk your friend into swaping the strut to see if its that, instead of going out and not working a strut can seaze up and feel really stiff and knock over a bump.
Japostol78
Sep 7, 2008 09:36 PM
hybrid90
Suspension & Brakes
14
Feb 27, 2008 03:35 PM
ke98248
Oct 23, 2007 12:10 PM
Spade
Jun 20, 2002 07:43 AM
