Help with wires???
I just picked up a 94 integra Ls Shell. Everything was strait except there were some wires on the harness and at the ecu plugs that were cut...I already figured out the o2s secondary was one...there's a light green wire off of i think it's plug D. It's green with a blue stripe...anyways I've come to the conclusion that it's either FLR1 or SG2. Neither of which i know what they are. Also, the VSS (speed sensor ) wire is cut at the clip by the passanger side shock tower. I checked on the ecu plug and it's pluged in still... it's solid orange. I followed itup to the fire wall and that's as far as i could go with it... what else could it be to? If anyone can help me with this I would appreciate it. Already searched and even called honda. lol they said bring it in and we'll charge you your first born child hahah. Thanks in advance.
anyone know? lol everyones quick to help when it comes to input on a motor swap or simple stuff...where's the tech's at??? See wires and run lol. j/k anyways hopefully someone can help out. I'd hate to have to replace the whole harness because of a wire or two
man..i been sittin by waitin for some help with this and didn't no one say nothin. THANKS
haha. oh well i figured it out...ended up bein map ground and the speed sensor...
Sorry. I woulda helped you if I was at home(im at work now) and had my Helms handy. Maybe you should think about getting one for helping you in your new car.
tuname420
Welding / Fabrication
Jan 1, 2006 04:17 PM
AGPSuperstar
May 7, 2003 03:20 PM
