crx distributor?
Old Mar 4, 2006 | 07:59 PM
manyakiexpi's Avatar
Default crx distributor?
today i went to the mechanic because my car has finally been able to run after i replaced a broken fuel injector and on the way to the mechanic the car turned off once. when i got there the car turned off twice as the guy tried to park it in the garage to chek it. i saw him use a screw driver and pulled out each s-plug wire to see if theres a spark as i cranked it and he said there wasnt. so im wondering is it the distributor cap and rotor that has gone bad? but than again i changed those too like last week but is there ne way that these can go bad that fast? and if i check it how do i know? or could it just be the whole distributor?
Old Mar 4, 2006 | 08:37 PM
Rywire's Avatar
Default Re: crx distributor? (manyakiexpi)
its prolly the coil or ignitor
Old Mar 4, 2006 | 08:45 PM
are those easy to replace? im such a newbie so yea. is the coil and the ignitor inside the distributor?
Old Mar 5, 2006 | 02:34 AM
K20EF8's Avatar
Default Re: (manyakiexpi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manyakiexpi &raquo;</TD></TR><TR><TD CLASS="quote">are those easy to replace? im such a newbie so yea. is the coil and the ignitor inside the distributor?</TD></TR></TABLE>
Rywire.com sells them, pm me if you need a hookup on one
RSX2SIcivic
Oct 27, 2008 11:08 PM
SI_niki
Jun 15, 2004 07:54 AM
TwoPointZero
Mar 27, 2004 07:23 AM
psicrxsi
Sep 28, 2003 10:36 PM
weakGOODJunKieS.com
Aug 30, 2003 02:25 AM
