JDM Climate control install
Old Mar 4, 2006 | 06:05 PM
vc's Avatar
vc
Default JDM Climate control install
I need help with the jdm climate control install, many people said it was plug and play, but when I took out my usdm one and tried to put the in the jdm one, it wasn't plug and play.
Do I have to buy the jdm harness?
here is a picture of the jdm climate control plug connector
Old Mar 4, 2006 | 06:16 PM
Echo7847's Avatar
Default Re: JDM Climate control install (vc)
They use a different harness. Not plug and play.
Everyone that buys them just swaps the faceplates and the blubs over.
Old Mar 4, 2006 | 06:19 PM
vc's Avatar
vc
Out with the old
and In with the new
Bump for some help with the climate control install.
Old Mar 4, 2006 | 06:21 PM
vc's Avatar
vc
Default Re: JDM Climate control install (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">They use a different harness. Not plug and play.
Everyone that buys them just swaps the faceplates and the blubs over.</TD></TR></TABLE>
Where can I get the harness at?
Old Mar 4, 2006 | 06:25 PM
Sleepy_Red_hatch's Avatar
japan
for real tho...o think cxShoe can find anything jdm...contact him
Old Mar 4, 2006 | 06:29 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vc &raquo;</TD></TR><TR><TD CLASS="quote">
Where can I get the harness at?</TD></TR></TABLE>
Just swap the faceplate and bulbs. Along with the harness you need to find, you need the sensors and heater box as well. Unless you have a smashed SiR, you won't find those parts.
Old Mar 5, 2006 | 11:56 AM
vc's Avatar
vc
Default Re: JDM Climate control install (BlueIntegraBoy)
Ok I changed the faceplates n stuff.. now my fan isn't working.. I get no air coming out of the vents, and the mount under the climate control to hold the heat/cold wire is broken, what can I do?
Old Mar 5, 2006 | 12:01 PM
raiden571's Avatar
does the blower motor even kick on? i would check the simple **** like your fuses. the wire is busted off the climate control, ive never looked at one, but can it be resoldered?
Old Mar 5, 2006 | 02:51 PM
vc's Avatar
vc
Default Re: (raiden571)
Fuses are fine.
My headunit and fan does not work.
Will I have to replace the headunit / climate control harness?
Old Mar 5, 2006 | 03:07 PM
dohcVTECeg2's Avatar
Default Re: (vc)
u sure you plugged everything back in?
Old Mar 5, 2006 | 03:16 PM
vc's Avatar
vc
Default Re: (dohcVTECeg2)
Yeah, I'm sure I plugged everything back in.
The cigarette lighter works
The headunit does not work
There are no air coming out of the vents
The climate control does not light up
Modified by vc at 4:27 PM 3/5/2006
Old Mar 5, 2006 | 03:28 PM
Default Re: (vc)
Cigarette lighter and radio are the same fuse, so it can't be the fuse. Did you do the cluster swap at the same time? You wouldn't happened to have unplugged the ground wire behind the gauge cluster? It's a single black wire that attached to the dash bracket.
Old Mar 5, 2006 | 03:30 PM
vc's Avatar
vc
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Cigarette lighter and radio are the same fuse, so it can't be the fuse. Did you do the cluster swap at the same time? You wouldn't happened to have unplugged the ground wire behind the gauge cluster? It's a single black wire that attached to the dash bracket.</TD></TR></TABLE>
Yes I swapped the clusters at the same time.
I don't know if I detached the black wire.... but when I was taking out the climate control, I did tug a bit hard.
Old Mar 5, 2006 | 03:33 PM
Default Re: (vc)
I don't know if I detached the black wire.... but when I was taking out the climate control, I did tug a bit hard. </TD></TR></TABLE>
Normally the ground wire wont detach unless the clip on the plug is pressed. But check it anyways.
Old Mar 6, 2006 | 11:43 AM
vc's Avatar
vc
-Rear defroster isn't working
-The cigarette lighter works
-The headunit does not work
-There are no air coming out of the vents
-The climate control does not light up
somebody help please.
Modified by vc at 8:26 PM 3/6/2006
Old Mar 7, 2006 | 07:24 AM
b204dr's Avatar
Default Re: (vc)
try grounding it out some where else some times the plug grounds suck imo
-JSpecEk*9-
17
Oct 2, 2005 07:46 AM
YodajdmEK4
Dec 21, 2004 11:02 AM
Anhjockz
Oct 26, 2003 12:57 PM
wickedEFguy
Apr 30, 2003 03:05 PM
